Hotrodders Bulletin Board
#1
Grinder time... steering arm or spindle?
I just got the brake and steering kit for 37 Spindles with the flat steering arms. The steering arms have some interference at the spindle and one or the other needs to be ground down, or the kit returned. Which do I hack on, one or both? I am a little nervous about removing material on stuff that steers the car.... so returning the kit is an option, I just don't know who sells another complete kit - I need simplicity.
A person might think that by "kit" they mean that the stuff works together. Maybe that's just my interpretation. |
#2
re: Grinder time... steering arm or spindle?
A picture would help, or a little better explanation of exactly where the interference is.
Centerline HotRodsAndHemis.com "Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." |
#3
First thing I would do is, get a hold of the supplier, asking why you need to be grinding on their parts.....Maybe, there is another way around this problem.
#4
Pictures
Here's what I have.... the caliper brackets are on the correct sides (per their markings) and the caliper is on the 2:30 o'clock position (ish). the interference is between the steering arm and the caliper bracket. It looks like quite a bit of material would have to be removed. I double checked with the orientation of everything with the drawing... I compared it to the old parts and it looks close (old spindles were factory with the arms part of the spindle).
Thanks for looking. Last edited by Slomotion34 : 07-03-2008 at 06:07 PM. Reason: inaccurate |
#5
The kits from speedway comes with a bushing now.You use to have to grind them.A friend just bought one from speedway and it came with bushing.
#6
Hopefully they are open tomorrow...or Monday. I just got my kit in last week... there's no bushing in it.
#7
A couple of grade 8 washers inbetween the arm and spindle would do the trick. Or a single washer and a little grinding on the arm and a little on the caliper bracket would do it. The side you would be grinding is not the stressed side anyway. The upper leg on the caliper bracket is the one that takes the load.
The forged arms don't have that fitment problem. Here is something to think about...I wouldn't use the flat arms on a street car. Flat arms need to be used with heim type ends.... Later, mikey
BE different....ACT normal. |
#8
I am definitely going to go with the forged arms, it looks like the flat ones won't have enough clearance under the frame anyway. Thanks!
#9
The forged arms come in several types, some are formed with a drop to clear the radius rods, hairpins, 4 bars, frame or whatever to accomodate dropped axles. Later, mikey
#10
I bought the same arms and had to weld on 2 1/2" spacers for them to clear the calipers. Seems like everything I've bought from Speedway I've had to modify or buy something else to make it work. And all the brake parts and steering stuff has come from them, and THEY said would work. right! Good luck. |
#11
You could not pay me enough to do a calalog type project build. I said for years that aftermarket stuff should be labeled "fits all, but fits nothing". |
Back to top |
Similar Threads for: "Grinder time... steering arm or spindle?"
| Bend a Steering Arm? | 1Fine69 | Suspension - Brakes - Steering | 7 | 03-17-2006 03:25 PM |
| Hotrodders Knowledge Base: Suspension - Brakes - Steering | Jon | Suspension - Brakes - Steering | 0 | 11-26-2005 05:29 PM |
| Idler Arm help after front tire change | 360Camaro | Suspension - Brakes - Steering | 1 | 12-28-2003 10:49 AM |
| front end popping | maddmaxx | Suspension - Brakes - Steering | 4 | 11-15-2003 07:24 PM |
| Spindle help | DoubleVision | Suspension - Brakes - Steering | 5 | 06-25-2003 12:18 AM |
