Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-03-2008, 04:29 PM
Slomotion34's Avatar
Slomotion34 Slomotion34 is offline
Grinder time... steering arm or spindle?
I just got the brake and steering kit for 37 Spindles with the flat steering arms. The steering arms have some interference at the spindle and one or the other needs to be ground down, or the kit returned. Which do I hack on, one or both? I am a little nervous about removing material on stuff that steers the car.... so returning the kit is an option, I just don't know who sells another complete kit - I need simplicity.
A person might think that by "kit" they mean that the stuff works together. Maybe that's just my interpretation.
Old 07-03-2008, 05:14 PM
Centerline's Avatar
Centerline Centerline is offline
Moderator
 Centerline's barnstar
Wiki Edits: 38
re: Grinder time... steering arm or spindle?
A picture would help, or a little better explanation of exactly where the interference is.
Centerline
HotRodsAndHemis.com
"Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 07-03-2008, 05:24 PM
poncho62's Avatar
poncho62 poncho62 is online now
Moderator
 poncho62's barnstar
Wiki Edits: 4
First thing I would do is, get a hold of the supplier, asking why you need to be grinding on their parts.....Maybe, there is another way around this problem.
Old 07-03-2008, 06:06 PM
Pictures
Here's what I have.... the caliper brackets are on the correct sides (per their markings) and the caliper is on the 2:30 o'clock position (ish). the interference is between the steering arm and the caliper bracket. It looks like quite a bit of material would have to be removed. I double checked with the orientation of everything with the drawing... I compared it to the old parts and it looks close (old spindles were factory with the arms part of the spindle).
Thanks for looking.
Size:  153.0 KB  Click image for larger version
Old 07-03-2008, 09:03 PM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Build them like you like them
The kits from speedway comes with a bushing now.You use to have to grind them.A friend just bought one from speedway and it came with bushing.
Old 07-03-2008, 09:07 PM
Hopefully they are open tomorrow...or Monday. I just got my kit in last week... there's no bushing in it.
Old 07-04-2008, 03:01 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 113
A couple of grade 8 washers inbetween the arm and spindle would do the trick. Or a single washer and a little grinding on the arm and a little on the caliper bracket would do it. The side you would be grinding is not the stressed side anyway. The upper leg on the caliper bracket is the one that takes the load.
The forged arms don't have that fitment problem.
Here is something to think about...I wouldn't use the flat arms on a street car. Flat arms need to be used with heim type ends.... Those ends get loose pretty fast on the street, as there is no dust seals and no good way to keep them greased.
Later, mikey
BE different....ACT normal.
Experience is something you don't get until just after you need it
Old 07-06-2008, 10:16 AM
I am definitely going to go with the forged arms, it looks like the flat ones won't have enough clearance under the frame anyway. Thanks!
Old 07-06-2008, 11:21 AM
Wiki Edits: 113
The forged arms come in several types, some are formed with a drop to clear the radius rods, hairpins, 4 bars, frame or whatever to accomodate dropped axles.
Later, mikey
Old 07-08-2008, 05:52 PM
PureC4 PureC4 is offline
Thanks for looking.
I bought the same arms and had to weld on 2 1/2" spacers for them to clear the calipers. Seems like everything I've bought from Speedway I've had to modify or buy something else to make it work. And all the brake parts and steering stuff has come from them, and THEY said would work. right! Got a drawer full of extra stuff, including their drop spindles. Maybe use them on my next project. Anyway sorry for getting off track... but I'd return them if I could and not grind on them.
Good luck.
Old 07-08-2008, 06:22 PM
F&J F&J is offline
Good luck.
You could not pay me enough to do a calalog type project build. I said for years that aftermarket stuff should be labeled "fits all, but fits nothing".
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Grinder time... steering arm or spindle?"
Bend a Steering Arm? 1Fine69 Suspension - Brakes - Steering 7 03-17-2006 03:25 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 05:29 PM
Idler Arm help after front tire change 360Camaro Suspension - Brakes - Steering 1 12-28-2003 10:49 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 07:24 PM
Spindle help DoubleVision Suspension - Brakes - Steering 5 06-25-2003 12:18 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
