Grit in my oil filter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2008, 03:04 AM
I just did a oil change in my 78 malibu and decided to cut open the filter to see how much crap might be floating around in my oil. It's a high mileage 305 so I know it's pretty worn but when I looked in the filter I found allot of black gritty junk that I figure must be carbon. I know what metal fillings means if it's in the oil but why would I have so much of this gritty carbon considering I last changed the oil only 5 months ago?
Old 09-10-2008, 06:59 AM
Have you run a fuel system cleaner through it?
Shane
Old 09-10-2008, 10:50 AM
A high milage engine may consume a lot of oil. Carbon builds up and then when you "step on it" the carbon breaks loose. Most goes out the exhaust, but some gets in the oil. The oil filter then traps it. So far, it's a normal situation.
Note: The bad news is that most oil filters have a bypass valve that opens when the oil is cold and thick, allowing unfiltered oil to get to your bearings. Cars which are only run for short distances suffer most from this.
Anyway, just how large are these gritty particles? Only small particles should get by the rings. I'm not familiar with the systems on a 78 Malibu, but does it have an EGR system? If so, I'd check it out carefully.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
chevy 350 oil filter housing help briansansone Engine 10 10-24-2010 01:39 AM
2.8 S-10 Blazer oil filter CrashFarmer2 Hotrodders' Lounge 2 02-21-2007 11:58 AM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 01:47 PM
