Grizzly's English Wheel - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 02-27-2014, 10:01 AM
Originally Posted by tech69 View Post
it's theuraputic(sp?) I tell ya. the noises it makes is relaxing too, and I especially like the slight crunching noise it makes when it smooths out a rough surface. What a stress reliever. This thing kicks butt.
Can't wait to set mine up.
I will have to do something about the lower piece. It moves around when under pressure but I can just put a couple tacks in there and grind it down til it's stout. No complaints, this thing rocks.
Did you check out the MM link? It shows how to firm up the lower piece.
Basically adding more material to the sleeve.
Thanks for the update!
  #77 (permalink)
Old 02-28-2014, 06:37 AM
put up or shut up
sweet. I'll do something like that. If I use tack welds it will just scrape in other areas as it's moving up and down. Adding more sounds better. Might plug weld a little piece of metal and shave it down as well. Not in a hurry though, it seems to work good enough for me at the moment. If it can make a bowl very accurately I think I can make a tank for my bike this weekend, or at least get started on it.
One thing I'll say, the roundest die looks pretty useless so far. It looks like it needs a flat spot, but I'm sure there will be a use for it.
Thanks for the link.
  #78 (permalink)
Old 02-28-2014, 09:51 AM
About the only time I know you will use the roundest die is if you have a detail line going through a panel. I don't believe you will want much of a flat spot on it but you might decide to add them to your lower crown dies at some point.
One interesting thing you will find is the flatter wheels will tend to cause the metal to droop (curve) in front of the wheel while the real high crown wheels will tend to make the metal droop to the sides of the wheel. These panels tend to oil can causing them to have a lot of tension. It os also really helpfull to have help on the larger pieces to support the sides to limit the droop.
If you notice the pros do a wash over when they finish a panel which is running the whole panel through the wheel under light pressure to relieve those stresses.
Expecting these things and planning for them helps when you are working on a larger low crown panel.
If it is in your budget, I really found John Glovers videos to be very helpful when I built mine back in 1991. His videos are still out there. He was a metal shaper for Ford Motor Company for years in their design department and is a real artist with the wheel. On one of his videos he makes a model A front fender from scratch including the wire edge on the wheel and then fusion welds it together with O/A. Fascinating viewing.
It is cool to see you guys enjoying this new phase of metal working. Keep the feedback coming.
John
The Following User Says Thank You to John long For This Useful Post:
tech69 (02-28-2014)
  #79 (permalink)
Old 02-28-2014, 10:10 PM
tech69, any issues with installing the upper wheel? It says you may need a hammer. No way mine was going to go. I messed it up already and sanded the pin down so it would fit the bearings. Now its so loose its crazy.
(in the frame) fits perfect in the bearings. Something not right.
Pretty unhappy right now.
  #80 (permalink)
Old 02-28-2014, 11:17 PM
put up or shut up
John
thanks for your advice.
  #81 (permalink)
Old 02-28-2014, 11:22 PM
put up or shut up
no, the pin went right in but the arms were super loose and I need a washer to center the upper wheel to the lower die. It definitely has issues as more pressure is applied but it's the same issue as William Longyard was having, the lower die moving. I figure if it can make a bowl that's nearly perfectly symetrical than I can toy around with it for a while and hold off on some improvements, but I definitely want to do what William Longyard did, that was a great idea.
  #82 (permalink)
Old 03-02-2014, 10:07 AM
put up or shut up
messed with the E Wheel yesterday. I feel the small wheels help in tight spaces like this small tank.
It got real shaky when rolling the edges here. Need to make it more stout, but it did the job nonetheless.
still a couple edges I need to soften up a little bit. will have to grind down a dolly a little bit to accomodate that radius at the ends to hammer form it a bit. Just want to get the radius edges nice and it will be good enough to weld to the center piece.
coming together but not out of the woods yet.
  #83 (permalink)
Old 03-02-2014, 11:28 AM
Very cool!
  #84 (permalink)
Old 03-02-2014, 11:43 AM
put up or shut up
definitely not out of the woods yet though. I imagine since this tank doesn't have an all around radius and the radius is generally at the edges, this will make it tough to blend it all in, but will help tons on containing warpage from welding. I think I will weld it to the top middle section first so I can planish it all out and the bottom last cause I can hide the imperfections. It's gonna be tough to tie those pieces together with the middle so I will make a cardboard jig of sorts. Anyhow, this e-wheel kicks major butt!
  #85 (permalink)
Old 03-02-2014, 07:11 PM
tech69, what gauge are you using? Just curious.
  #86 (permalink)
Old 03-28-2014, 11:16 PM
Got my new pin from Grizzly today. Its wrong. One unhappy camper!
I want to wheel! Done waiting on them. I'll figure something out.
Anybody else using there's? Love to see more pictures. Need some encouragement right now.
  #87 (permalink)
Old 03-29-2014, 12:12 AM
put up or shut up
I'm currently using 18 gauge. It seems like it doesn't move metal much. I think it's a great wheel for a tight radius but I didn't feel it do much other than smooth out parts that were already close, but it will certainly smooth out some stretching in the shot bag. I don't have enough experience with anything else to compare but I've seen video and it seems that the bigger wheels do much more at a quicker pace. I do like what it can do when smoothing out after air planishing. Just don't see much in the way of shaping panels with it.
  #88 (permalink)
Old 03-29-2014, 04:51 PM
You will find for larger panels with a low crown the E Wheel is all you need but for something like the gas tank or the trunk drop down I am working on the planishing hammer or shot bag will get the rough shape into it so much faster.
I am looking forward to seeing your tank Henry. I hope you will be posting pictures.
John
  #89 (permalink)
Old 03-30-2014, 12:07 AM
put up or shut up
yeah, I figured that. Seems good for low crowns finessed in the exact spot you need it...too subtle for stretching in the bag, and much more accurate than bending over the knee. I'm considering a HF wheel but can wait...til this coupon is about to expire.
  #90 (permalink)
Old 09-11-2014, 05:14 PM
Got around to adding bushings in mine. Tightened up the upper.
Now to deal with the lower. Had a little fun with it. Was surprised on how it smoothed some nasty hammer marks in some 18G.
Not so easy finding 12mm I.D. bushings. Grainger was nice and helpful.
Nobody local had them so I ordered through Grainger.
Jury is still out.
Name:	metal 9ten14 002.JPG
ID:	173354   Click image for larger version
Name:	metal 9ten14 014.JPG
ID:	173362   Click image for larger version
Name:	metal 9ten14 018.JPG
ID:	173370   Click image for larger version
Name:	metal 9ten14 024.JPG
ID:	173378   Click image for larger version
Name:	metal 9ten14 012.JPG
The Following User Says Thank You to Nonhog For This Useful Post:
hduff (09-19-2014)
english wheel nissan Garage - Tools 3 03-02-2010 07:56 AM
How to Use an English Wheel? ScottRods2945 Body - Exterior 3 05-03-2007 05:38 PM
english wheel racer57 Hotrodding Basics 3 03-17-2007 06:27 AM
Using an English wheel Daz_uk Body - Exterior 6 12-10-2005 12:28 PM
English wheel ianhealey Garage - Tools 11 08-19-2004 08:30 AM
