in ground auto hoist - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 02:18 AM
inground hoist
I have 2 of the 2 post inground hoist and I am looking for info on installing the plumbing Would appreciate any help I can get.
Old 05-26-2008, 06:39 AM
2 post hoist
There should be a pipe fitting at the top of the housing that you attach a copper tube the full diameter as the fitting, and take that to your operating manifold. You have an operating manifold for each cylinder. You locate these so you can run both at the same time. There should be a fitting on the mainfold to come from the air supply, and a common one that goes to the cylinder, and an exhaust one with a muffler on it. There should be some sort of dip stick to determine oil level in the cylinder unit. You install this in a trench in the floor, or a large plastic conduit. You can just fill the hole with dirt, then pour concrete over the opening, too, after you are certain that everything works and does not leak.
Old 08-26-2008, 08:13 AM
wallace holliman
Originally Posted by pontiac owner
I have a line on several of the in ground air over oil hydraulic auto hoists from a closed auto dealer. A couple are the two post type, but most are the single post type. New above ground ones cost about $2 grand. One of these will set you back a few hundred bucks. They are located in Central Illinois. Any one hwo might be interested please email me.
I am interested in a single post lift please contact me at ************************* or call **************
Last edited by OneMoreTime; 08-26-2008 at 09:47 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 08-26-2008, 09:04 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Wallace,
Take a look on craig's list or e-bay, I brought a 9,000# above
ground lift for $500. it was still installed went & made sure it worked,
the next day it was removed & I took it home,
just waiting for the pad to be pored now.
Rich
checked today on craig's list
http://philadelphia.craigslist.org/pts/812030944.html
Fuel gauge help dpjim2 Electrical 7 05-27-2006 03:16 PM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
Auto zones. BarryK Hotrodders' Lounge 49 04-28-2006 10:32 AM
Netural Safety switch StingRay69 Electrical 6 09-23-2005 08:14 AM
Auto and timber finishes candyandy Body - Exterior 10 06-21-2005 11:37 PM
