ground strap over thinking - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2007, 03:42 PM
Ok I might be over thinking this. I read in a mag that I need a ground strap from the firewall to the engine and an aluminum head was ok. I did the ground strap but was wondering if my black oxide studs in the block would cause a bad ground?
I have a trunk battery with it grounded to the frame. I have a ground strap from frame to block. I just installed a ground strap from firewall (brake booster bolt sandwiched to bare mettle on firewall) to the head. Does this look ok? I have had starting issues in the past due to an old alarm and a jump in the tach at 1000-1500 rpm but nothing else. I have 14.5 to 15 volts. I have my grate grandfather's 55 chevy and I don't think it ever had ground straps.
Thank you for your help,
The Tom
Old 08-12-2007, 08:17 AM
Ground strap
That sounds ok. If you have any doubts do a voltage drop test from the ground terminal on the battery to wherever in the system. Ideally you shouldn't see more than .2 volt while loading the circuit you're testing.
Positive ground maddogmodl Electrical 15 02-03-2007 10:49 AM
Running a proper ground (total rewire) murrsue Electrical 6 01-23-2007 07:04 AM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
what stereo wires under carpet? bullheimer Electrical 19 05-06-2005 06:37 PM
Ignition Trigger Ground Noise TurboS10 Engine 12 02-28-2004 10:44 AM
