ground surface prep - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 08:05 AM
ground surface prep
Engine to frame, Frame to cab, Elec dash ground surfaces, other: What do you use on the metal surface to enhance longevity of surface contact and to prevent rust? ...antisieze? dielectric grease?
Old 08-27-2010, 08:07 AM
T-bucket23's Avatar
Wiki Edits: 26
Dielectric grease and star washers
Chet
Old 08-27-2010, 08:48 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Pardon the interruption...Good question. I've been thinking about this too as it gets closer to wiring time...would it be best to find a place on my block or will a place on the aluminum heads be just as good for my engine ground? And do I need to sand to bare metal on the body and frame,dielectric grease, and then just repaint over the bolt/nut connection? Or will a star washer "bite" through the paint to metal and provide enough contact?
thanks
Old 08-27-2010, 09:33 AM
T-bucket23's Avatar
Wiki Edits: 26
thanks
I would clean it bare, get the connection locked down and then you can paint around it. I prefer attaching the ground to steel, Aluminum reacts funny with most metals, especially where electricity is involved.
Chet
Old 08-27-2010, 01:08 PM
i do like t-bucket said grind clean ground it and paint over it
Old 08-27-2010, 01:13 PM
T-bucket23's Avatar
Wiki Edits: 26
The star washers are the key to a long lasting connection
Chet
Old 08-27-2010, 02:05 PM
Hwyhogg's Avatar
thanks Yeah, thought the iron block might be preferred over the aluminum heads. RTYAUCH, where in AL? I've got some family in Clio and Muscle shoals
Old 08-27-2010, 05:35 PM
Athens about 30 -40 min east down 72 from Muscle shoals
Old 08-27-2010, 07:58 PM
Joe G's Avatar
I use dielectric grease on the terminal, star washer, and screw.
As a rule, I only use ground screws that are threaded directly into the metal they are attached to. Self-drilling Tek screws work great for grounding to frames and sheet metal.
On a car with the battery mounted in the rear, I weld 3/8" bolts to the RH frame rail near the battery and near the engine, and nut the ground cables to them with star washers and dielectric grease.
Old 09-01-2010, 01:21 AM
bentwings's Avatar
bentwings
The surface oxide on aluminum is aluminum oxide which is a very good insulator. Anodized aluminum is even beter insulator. Any time you have to depend on a ground on aluminum you risk having trouble eventually.
Stainless wire brush the aluminum then immediately star washer and clean bolt. thru the connector. Cover it with dielectric grease.
I just had a bad ground on an aluminum solenoid housing. I skined it with a carbide cutter and new nut and star washer. It will work for a while but the first hint of trouble I'll have to do it again. Glad I have new solenoids in both doors.
Old 09-01-2010, 03:16 PM
Hwyhogg's Avatar
thanks for insight on the aluminum problems..will use block instead of head
Positive ground maddogmodl Electrical 15 02-03-2007 11:49 AM
Running a proper ground (total rewire) murrsue Electrical 6 01-23-2007 08:04 AM
Ignition Trigger Ground Noise TurboS10 Engine 12 02-28-2004 11:44 AM
surface prep 58Delray Body - Exterior 7 12-19-2002 05:51 AM
metal prep Busted Knuckles Body - Exterior 10 12-10-2002 11:00 AM
