Grounded - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2003, 10:29 PM
Grounded
With the battery in the trunk, why should you NOT ground to frame and frame to engine?
Old 10-24-2003, 04:00 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I think you SHOULD!
Alan
54 Chevy Pickup
Old 10-24-2003, 05:02 AM
302 Z28's Avatar
You should, but I would run a ground conductor from the negative side of the battery all the way up to the engine with the positive cable and ground it to the engine. Then ground the engine to the frame and the engine to the body.
Vince
Old 10-25-2003, 05:57 AM
I think your question is "why not use the frame as the ground to the engine by running a short ground wire from the battery to the frame in the rear and then another short wire from frame to the engine, saving a long ground cable? The answer is that the steel frame has much more resistance than the wound copper wire in the battery cable. Starting will be unreliable if there is anything other than a fully charged battery to provide maximum amps. There are numerous threads discussing this in previous posts and Ron Francis Wire Works instructions cautions against this in their installation instructions. Another discussion item is using heavier wire from alternator to starter/battery when you start moving the battery more than 2 feet from the alternator. Same theory, sort of. The longer the cables you run, the bigger it must be to carry the current, and we all know you use copper cables/wiiring because of less resistance than steel.
Trees
Old 10-25-2003, 04:32 PM
dollybud's Avatar
Talking
I agree with 302 and Trees. Make sure you use 1.0 gauge wire from trunk to engine block. Some cars like Camaro's have sub frames which can also become a factor. By grounding strictlly inside the trunk you open yourself up to all kinds of electrical problems. Been there!
Tom
Old 10-25-2003, 04:40 PM
Go to this site http://www.madelectrical.com/ and read what electrical guru Mark Harmon suggests. He also sells the Ford type solonoid kit that will make your 15 foot length of positive battery cable energized on cranking only. That is a safety issue with trunk mounted batteries. He suggests an ignition disconnect switch be mounted in this type of modification. He recommends it to be on the negative cable, but if you plan to race, NHRA requires it to be on the positive cable.
Old 10-25-2003, 09:57 PM
4 Jaw Chuck's Avatar
Can you say..."ground loop"!
— Han Solo
Old 10-26-2003, 09:17 PM
Trees answered my question. I knew you shouldn't use the frame as a ground, but was wondering why. I have a shut off at the engine on the positive, never heard of putting it on the ground wire. Thanks
