Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Grounding
Thread: Grounding
Old 12-26-2012, 01:03 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
When I set my cars up with the batery in the back.. I weld a bolt on the frame by the battery and one by the motor.. I then run a ground to the frame from the batery, Then run a ground to the motor and cab from the front bolt..I then run a hot from the battery to the battery kill switch mounted as close to the battery as you can then from there to the starter.. (chevy)
Doing it this way, Makes the whole frame a ground..
