grounding issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2014, 09:37 PM
grounding issues
I have a 1981 buick regal limited with v8 chevy small block but I can seem to keep a good ground. Need advice if someone can help
Old 06-18-2014, 10:01 PM
techinspector1's Avatar
Wiki Edits: 326
Did you mean to say "I can't seem to keep a good ground"? You said you can keep a good ground.
If you really want some advice, I would advise you to go back to school.
Now, as far as establishing good grounds, you will need to grind down to bare metal and bolt a cable from the frame to the motor and from the motor to the body. Also, replace the positive and negative battery cables. I have seen them corrode down inside the covering where you can't see it.
Old 06-19-2014, 11:22 AM
Wiki Edits: 326
Originally Posted by Denny View Post
This isn't English Grammar 101 class.
It is if he's talking to me. Someone has to correct bad english.
Old 06-19-2014, 12:04 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I typically grind the Paint, use a Star Washer and the put Lithium Grease between the Cable, Star Washer and Frame-
Old 06-19-2014, 01:00 PM
T-bucket23's Avatar
Wiki Edits: 26
You didn't say where your grounding issues were. The above posts about star washers is in my opinion the best way to attach grounds. Quality fasteners and cable ends will make it easier to maintain ground connections. I don't use lithium grease but I will use dielectric grease on connections that are exposed to the weather.
Chet
Old 06-19-2014, 03:41 PM
EOD Guy's Avatar
You should grind the area to remove the paint before you install a star washer. Bare metal to bare metal is the best choice when doing or redoing ground connection points. I always use star washers, as they dig into the metal. Install the washer and fastener and paint over the area. If I had a high end paint job on the frame I'd still remove the paint, I'd just be very careful.
Old 06-20-2014, 02:31 PM
Thanks for the information guys. But Mr . Tech I didn't ask you directly this is a fourm if you didn't realize
Old 06-20-2014, 03:38 PM
da34guy's Avatar
Musta slept thru english class !!!!!!!!!!!!!
Old 06-20-2014, 04:03 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Wow, you can be a real jerk tech... speaking of schooling, look up civility, it seems to be a lost skill today.
As to grounding issues... Drill and tap the frame, apply dielectric grease to a long stainless bolt, throw a star washer on it and then thread it through the opposite side of the frame. Now use another star washer and install a stainless lock nut. You now have a stud that is threaded into the frame, ready for you to install a ground. Use lots of dielectric grease as you assemble the ground to the stud, use a couple more star washers and a stainless nut.
Check to make sure your grounding straps are good from the frame to motor, and from the body to the frame. if they aren't you can buy generic grounding straps from NAPA.
This has worked well for me in the past. Anytime I need to ground something I use this principal.
Hope that helps!
PS: I didn't spell or grammar check this post.. 'cause it's the Hotrodders website, not an online English course...
John
The Following User Says Thank You to lakeroadster For This Useful Post:
Denny (06-20-2014)
Grounding COmponents? 65malibuSS Electrical 30 05-14-2014 07:53 PM
Grounding rustman Electrical 3 12-26-2012 01:21 PM
grounding? JONESJONES Body - Exterior 17 03-31-2006 06:30 PM
Grounding Cans? Rathimis Electrical 6 01-21-2005 07:12 PM
battery grounding bigford556 Electrical 6 11-18-2004 05:55 PM
