grounding mig welder?
Hey guys, I bought a Lincoln Mig setup (110v). The instructions say to ground this unit with a grounding pole....does anyone really do this? I know you have to clamp what you are welding....but I have never seen anyone drive a post in the ground. I am anxious to start welding, don't want to rush into a unsafe situation. I am plugging the unit into a grounded 20 amp outlet via extension cord. Will I be ok? Please let me know your thoughts....thanks in advance for your help.
If your outlets are grounded like crankshaftkid says, you are good to go. Look around your house, usually by where the electric service comes in. You will find the copper coated rod pounded in the ground with a wire that runs into your breaker box's grounding lug. Some of the older houses have the grounding done through the water pipes, I don't remember why the welder companies don't like that kind of grounding.
later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Recent Garage - Tools posts with photos |
| mig welder | CaPrI_MaN | Garage - Tools | 11 | 04-03-2007 05:15 PM |
| Mastercraft Mig welder? Canadians eh | montea | Garage - Tools | 19 | 01-23-2007 11:24 AM |
| Using A mig Vs Stud Welder. | satexasf150 | Body - Exterior | 1 | 07-24-2006 10:08 AM |
| Seeking MIG welder recommendations | Slipangle | Garage - Tools | 6 | 10-20-2004 09:04 PM |
| Arc welder ~VS~ Mig Welder | ChrisMiddleron | Electrical | 15 | 07-08-2003 07:31 AM |
