Grounding regulator, ign relay, ign module? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2005, 08:44 PM
cboy's Avatar
Last journal entry: Finished
Is there any need to ground the metal cases on the regulator, ignition relay and ignition module? I ask because these are normally mounted directly to the metal body of the car and would thus be grounded - should a ground be required. To keep my firewall a little cleaner I am mounting mine to the inside of the wooden base supporting the car seat - and therefore the metal cases will not be grounded. I suppose this question would also apply to folks mounting the same items on a fiberglass bodied car.
Always learning...and sharing what I've learned.
Old 05-27-2005, 04:36 PM
docvette's Avatar
Wiki Edits: 12
Ground
Doc here,
I would Run a Ground Lug on the mounting Board.
The regulator for sure needs a ground...
Run 1 main #10 black wire from your ground cable to a lug on the board, then independent grounds to the components from there..you should be all good!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
1980 TA choke relay jdcoic Electrical 17 05-16-2013 07:09 PM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 12:34 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
