grounds - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 08:35 AM
Last journal entry: 27
grounds
after i raised my 27,s body 2" and installed spacers i noticed my throttle cable was welding itself to the firewall
i mentioned it to my mechanical geius guru and 1st thing out of his mouth was.
ground the engine to the frame and do the same to the body.
he gave me 2 of those copper braided straps.
ran one from the block to the frame a 12 inch strap.
and one from the body to the frame a 6 inch strap.
i cant believe i forgot the fact that almost every electrical gremlin i have ever chased was a ground problem.
i just figured i'd post this in case somebody gets brain damaged and forgets the importance of a good ground.
Old 03-06-2013, 08:49 AM
sedanbob's Avatar
Good reminder!
My sedan is a fiberglass car, so I had to run dedicated grounds for everything. If I re-wire a steel car, I think I might run the grounds just like I would for a fiberglass car. It would take a lot of the guess work out of "is this circuit properly grounded". My only electrical gremlin was an LED turn/park signal that had an internal short - new light, no more problem.
Old 03-06-2013, 08:32 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
starter
Of course the main battery ground cable is connected to the engine block because the starter is the only load that requires a very high amp draw.
vicrod
Grounds on my /what to i---us bsa_bob2 Electrical 11 07-21-2011 06:31 AM
Headlight grounds? Sir-x-Loin Electrical 26 08-12-2010 09:56 PM
grounds drchip Electrical 3 03-20-2010 07:07 AM
splicing grounds anglia48 Electrical 3 04-03-2006 06:47 AM
Headlight grounds LS6454 Electrical 8 02-19-2002 05:17 AM
