Grout filling after machining? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 03:44 AM
I have just assembled my 408ci sbc and have realised it would have been of huge benefit on a +040" block to grout fill the water jackets up to the welch plugs. Can this be done to a assembled engine or will it distort the cylinders too much?
Old 08-19-2008, 05:45 AM
This is much better done before machining I would not do it now due to possible distortion of the walls.
Old 08-19-2008, 05:56 AM
Last journal entry: PICTURE TEST
fill
Poplar opinion is that it needs done before machining. I personally have never filled a block after finish machining so i can't give you numbers on how much (if any) the bores will distort. You need to find the actual numbers the bores change (if any) and then make your decission weather or not it's worth it in your application.
What HP is this engine making??? What is the application of the engine??? drag only, street only, etc????
Keith
general machining tolerance question (not just automotive based machining) lowROLLERchevy General Rodding Tech 9 12-28-2007 11:33 AM
sbc valve springs .525 max lift NO MACHINING 383silverado Engine 3 09-06-2007 10:15 PM
Machining worn out rotors? staleg Suspension - Brakes - Steering 4 03-22-2006 08:15 AM
One more possible problem.....grout hardness TurboS10 Engine 2 09-27-2004 06:58 PM
Filling holes on a '56 Mercury roof Slipangle Body - Exterior 5 07-27-2004 07:32 PM
