Growling noise from the rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2012, 09:19 AM
dilligaf's Avatar
I am using a Camaro 10 bolt rear end that I am getting a growling noise from.. Where do I start to isolate the problem and what do I do to fix it?
Old 04-20-2012, 10:24 AM
Remove rear wheels, brakes and driveshaft and check for a rough feel when rotating pinion yoke by hand. Remove the axle shafts and inspect the shaft and bearing for pitting. Turn the pinion with axles removed and see if rough feel is eliminated. If not, its time to remvoe the diff and pinion and replace the four bearings involved.
03 Pontiac Grand Prix - Growling Noise S10 Racer Transmission - Rearend 4 11-21-2010 05:19 AM
Rear End Noise 77firebird Transmission - Rearend 2 05-27-2007 03:06 PM
Rear end noise need HELP!! mx jim Transmission - Rearend 2 10-17-2005 07:33 PM
Rear end Noise While Accelerating Auto-Part Transmission - Rearend 9 11-10-2003 10:36 AM
Rear End Noise? chevyteen17 Transmission - Rearend 1 04-01-2003 02:43 PM
