http://forums.hybridz.org/index.php/...mvsstealthram/
some numbers ------------- Im going to give kinsler a call monday and see what they have to say |
Running a common plenum defeats the purpose of using bike carbs since its not an IR setup. The easiest way to select bike carbs is power per carb, if 4 make 200hp on a bike then they should be ok to use 8 of them for 400hp. The problem is there aren't many carbed 4cylinder 200hp bikes...
I had zero chance to call them today- but look what i found.
http://www.twminduction.com/v8_kits/chevy.html |
Russ |
I have another contact in a different forum that is in the process of building a single plane crankshaft for a sbc (paul- is nuts...) He has a strong belief in that (the xram)manifold. I am going to try and get a hold about him about it, to see why he thinks it can support higher rpm then what is listed by them.
GREAT NEWS! so I got a hold of procomp i was thinking about it and really that doesn't make much sense that the rpm range on that manifold was so low of a rpm range.
steve extension #104 looked it up in his book and said "no- that listing is very wrong the range on that manifold is from 3500rpm to 7500rpm." this is in relation to part #PC3204 He also will be sending me a setup they ran on a ford (itb and efi) that he thinks i will be able to run with a bit of fab work. The only thing (according to him) that they don't have for the chevy manifold yet, is the linkage. as soon as i see that i will update. So this project is backup as far as i am concerned. Also kinsler yeah i got a quote for $4800 no thank you sir, i can make mine for way less. They did give me a hit up on some info on sizing. I was told for the power and rpm this will be making a 48-50mm throttle body is what i will be needing. Updates soon. |
Stan Chatwood
National Sales Representative Tel: (909) 605 1123 Extension 104 so this is what i received via email from stan. more to come. |
"I quoted you a few things. The $350 was for just the chevy manifold that these throttle bodies would set on.
This manifold goes for $1000 as pictured. Can sell you the throttle bodies and the chevy manifold for $900 Don’t have the linkage for this set up yet. It has been done though. The throttle bodies are 52mm" stan -------------- What do you guys think? for one 52mm is a bit big is it not? Also stupid question the threaded holes to the throttle bodies- those appear to be for injectors - but are threaded? lastly i don't see a spot for vacuum lines. |
it may not be ideal in size, but I'd say 9oo is such a good price for what you get, which amounts to a darn good start on a nice system, that I'd personally go for it. you wanted a high rpm system, so the size might actually work out for your particular needs. vacuum lines could easily be drilled into the spacer block under the TBs, as well as IAC ports etc. you'd also need to fab fuel rails, linkage, and a few other details, but overall, like I said, I think it's a very reasonable start for what you want to accomplish. Russ |
looking forward to seeing it run. ![]() Russ |
obd1 ecm ( i have a 86 iroc ecm) with the moates ostrich. look into the ostrich!
MS user here and LOVING it. I don't know if there is another cheap user friendly option out there. There are some that are user friendly and some that are cheap, but MS is both.
| OE Vortec intake gaskets with aftermarket heads/intake? | 04SilveradoMykk | Engine | 3 | 05-17-2009 11:07 PM |
| Matching intake ports heads/intake | dpjmw | Engine | 6 | 08-13-2007 07:29 PM |
| intake help?OFFenhauser low pro. ram intake manifold | 74chevyflat | Engine | 0 | 05-17-2006 07:49 PM |
| weiand stealth intake vs Edelbrock rpm intake | batman09 | Engine | 18 | 10-10-2004 01:41 AM |
| Intake manifold gaskets for alum. heads and intake | mustang66maniac | Engine | 6 | 02-20-2004 11:19 AM |
