gsx itb sbc intake fab? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2012, 06:41 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
Anyone build an intake with gsx itbs? I am thinking about fabing a manifold with itbs for my road race engine seeing everyone and their brother says to go fuel injection. If i am am going to go efi then i am going to do it right. and efi setup with proper velocity stacks and itbs is the way to go in my opinion.
each runner tapers down to the back throttle bodies which are 42mm
Name:	Back picture 2 with the all the throttle shafts open.jpg
ID:	61366   Click image for larger version
Name:	Back picture.jpg
ID:	61367   Click image for larger version
Name:	Front throttle shaft open.jpg
ID:	61368   Click image for larger version
Name:	the hole in each runner.jpg
ID:	61369   Click image for larger version
Name:	The odd fuel injector setup and the TPS sensor.jpg
Old 01-02-2012, 06:46 PM
for the point of each picture run your mouse over each attachment and the name of the file is what each of the picture is.
The throttle shaft also looks like it would be a really nice place to put a dry nitrous spray bar through. They have a bolt at the top and bottom that hold them together. Once removed you end up with two sets of two throttle bodies.
Name:	This is with the front set of throttle valves closed.jpg
Old 01-03-2012, 12:43 PM
depending on the spacing of the tb's and this intake u might be able to adapt those tbs to this intake manifold
http://www.ebay.com/itm/SBC-CHEVY-CR...item45ff5ae138
Old 01-03-2012, 08:10 PM
That is actually the manifold i was thinking of.
Would this be worth it compared to a good single plane carb?
Old 01-03-2012, 08:27 PM
How fast is fast enough?
The gsx tb's are WAY too small. They work well on small displacement 4 bangers but become a choke on anything with more than .5l per cylinder. So what is it worth- a 50hp loss at peak. With correctly sized lengths though they can pick up low end torque.
Old 01-03-2012, 08:40 PM
KA67_72's Avatar
Blight,
I've always loved IR setups. You probably will have to experiment with how you read(average) manifold pressure. I'm developing a 4 barrel throttle body and was very surprised about how little air it takes to idle a motor. Throttle response is going to be lightning quick at the price of tip in being hard to control. If you have a manual you may find yourself riding the clutch a lot trying to keep it from bucking. This looks like a cool project. Keep us posted.
That's a great price on that intake, but there are some things Procomp should leave sacred. Is there nothing they won't make cheap Chinese knockoffs of?
Kevin
Old 01-03-2012, 09:13 PM
4 Jaw Chuck's Avatar
Ap72 is right, I looked into this back in the 80's and there is a huge lack of flow capacity with motorcycle setups.
Would look cool though.
Outlawed tunes from outlawed pipes
Old 01-03-2012, 09:15 PM
I was looking for 48 mm from a boosa today no luck yet 42 is too small. 48 would about perfect.
tip in?
I am running an automatic with a 2400 stall
Old 01-04-2012, 11:12 AM
KA67_72's Avatar
Tip in is when you start to open the throttle off idle. It looks like the Hilborn SBC stuff starts around 2-3/16. I have an old one here that is 2-1/16.
Kevin
Old 01-04-2012, 01:29 PM
not meaning to argue with u but how is that possible, the tpi engines of the 80's used a single tb with twin 50mm blades,and most stock tbs have a single 70-75mm tb.
u would think that eight 42mm blades would flow a helluva lot more, whats the throttle blades on a typical 750 or 850 carb measure???
Old 01-04-2012, 03:17 PM
Kevin
how is tip in "hard to control" then?
Old 01-04-2012, 03:19 PM
the throttle body has to flow what cfm the head is at,at max lift. i can't remember the exact flow rate of each throttle body size but it also has to do with the shape of them also.
Old 01-04-2012, 03:28 PM
KA67_72's Avatar
With your converter you may not have issues with tip in. Even if you have problems with it at first, there are things you can do to sort it out like progressive linkages.
Kevin
Old 01-04-2012, 03:40 PM
how about a common plenum per 2 cyls, sinc eno 2 cyls on the same side will be pulling air at the same time if u built a common plenum feeding 2 runners using 2 tbs to feed each plenum, should solve the issue of them being to small.
though this woudlnt be a true itb setup, i would assume it would still act the same as if it were
Old 01-05-2012, 05:27 AM
I do not know enough to answer that question maybe someone else does. I just know what I am doing from what I have read/been told. That far in the tech on this subject I am in lack of information.
OE Vortec intake gaskets with aftermarket heads/intake? 04SilveradoMykk Engine 3 05-17-2009 11:07 PM
Matching intake ports heads/intake dpjmw Engine 6 08-13-2007 07:29 PM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
weiand stealth intake vs Edelbrock rpm intake batman09 Engine 18 10-10-2004 01:41 AM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
