gto independent rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 08:30 PM
Does anyone have any information or knowledge of installing a late model GTO independent rear into a 54 Chevy?
Old 12-30-2005, 09:25 PM
Well..........DOC.....
as a Moderator here, I would like to WELCOME
you here...
I have been watching this thread........and I guess that the new GTO rears are so new and in limited supply....that no one has done one yet.
I did a Corvette IRS years ago......now I just use the old standby...a 9 inch Ford
DEUCE....
Old 12-30-2005, 10:25 PM
Thanks for the reply, I just found out that the rear has anti lock brakes and traffic control. I guess traffic control is some kind of traction control. I was hoping it had niether, so I guess this just complicates things. How was it putting in the corvette suspension?
Old 12-31-2005, 06:34 AM
For me the Corvette IRS was fairly simple......I did it to a 56 Ford F-100....pickup. I took the bed off.....so everything was easy to see, get to and make work.
With the body on a car .....it would be a LOT tougher.
Old 12-31-2005, 07:07 AM
Actually I have the body of the frame and plan on cutting some of the floor out so when I do mount the body I can access the rear. I'm concerned now about computer controlled things.
Old 12-31-2005, 07:55 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
well the antilock potion of the design will be housed in the engine compartment, its usualy a large aluminium block with all the brake lines running in and out, so thats nothing to worry about ...
the traction control isnt much different, the gto uses engine control (cuts throttle, spark and fuel to reduce power) and then applies the brake to any wheel thats still not in check
by swapping the rear end, you eliminating both these systems, the only thing left would be the speed sensors that are located on the inner cv joints on the axle
in all reality, plenty of the corvette suspension swaps hotrodders have done came from cars that were originaly antilock, and sometimes even traction controlled cars, and its never effected anything , besides some guys not liking the look of the vehical speed sensor cog
from what i can gather, the GTO uses a rear cradle that holds most, if not al of the rear suspension components. this means that if you do that swap, you dont have to figure EVERYTHING out from scratch, most (if not all) of the parts will already be held in alingment to each other, and all you have to do is make your frame accept the assem,bly with a few crosmemebers and tabs
as an example, the newer mustang cobras with the irs, all the IRS components are on a cradle, and you could set up a corba and a 97 v6 mustang on lifts, gut the straight axle from the V6, and bolt the IRS right into it using the mounting points for the straight axle
RETRACTION, the corba irs is on its own cradle that will mount to the v6's frame, but it doesnt use the straight axle mounts, a friend of mine was nice enough to correct me, as he did the swap and cut the straight axle mounts off the frame afterwards .... a view of the complete cobra irs can be seen HERE
if the GTO IRS is on a fully contained cradle, you basicly just have to figure out how high to mount it for poper ride height, then build mounting points to hold it. mounting points could be anywhere tho
best bet is to either get on one of the GTO forums and see if someone is willing to take a bunch of pics of their IRS on a lift or such, or hit up the local poncho dealer and se if they have a gto in the show room
dress nice, act interested in buying a GTO, and crawl around underneith it
just try not to look like your casing the joint
Old 12-31-2005, 08:37 AM
Wiki Edits: 22
this just in from gtoforum.com
A vette has irs but no wheelhop.
A cobra has irs but no wheelhop.
a jaguar has irs but no wheelhop.
a GTO has irs and hops like a bunny.
the gto was designed for autocrossing, and straight line launching causes pretty good whel hope
and an online artical i found mentioned the GTO likes to swing the back end side to side when launching, trying to "find traction"
so if your going to be driving hard, or have a decent amount of HP on tap, the gto rear suspension might not be the best bet, if its just a crusier and you can get one, then it could be a batter bet then getting some other IRS that has like 90k miles on it already
Old 12-31-2005, 08:46 AM
Hey thanks for all the good info! So correct me if I'm wrong, but what you're saying is I can simply bypass all the traction control and anti lock brake stuff. As far as the wheel hop goes, that something I'll have to consider. I plan on putting a 350 zz motor with injection, and running it through a tremec 5 speed. I'm not planning on racing the car or anything, so I think I should be good there. Thanks again.
Old 12-31-2005, 09:18 AM
Wiki Edits: 22
you dont even have to bypass it, since the unit that actualy does the antilock function is under the hood, you just leave it on the donar vehical and forget about it
just run brake lines to the rear calipers as if you installed a ford 9 inch rear end or such
tho ONLY thing thats on the rear end thats realy antilock or traction control related is the speed sensor, if you look at the above link of the ford cobra suspension, youll see the 2 speed sensor cogs, one on each drive shaft nearest the center section
just pull the sensor out, and put them in the pile of unused parts, they wont have a computer to report to anymore anyways
« Air Ride | yoauto »
independent rear suspension truckboy Suspension - Brakes - Steering 6 05-25-2006 12:33 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 10:05 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
