Guess my peak power and win.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 06:37 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Ok, so you don't win anything.
I'm building an engine and I've run a hundred permutations through desktop dyno, but its not returning reliable results. Its saying that my peak HP will be higher than I think it should be. So, I need you all to guess crankshaft hp AND the peak's RPM. I'll be actually dyno-ing this engine in a couple months, so we all get to see who's closest.
-chevy 355
-9.15:1 CR, good quench, about .025" in the hole
-Vortec 906 heads, very light pocket porting
-stock valves, 1.94/1.5"
-performer intake, Qjet carb
-high performance manifolds... I'd guess about halfway between a stock manifold and small headers as far as performance.
-cam is melling part number 22124 flat hydraulic, 202/213 duration @50, 1.6 rockers for .428/.437 lift on a 110 LSA
I need your opinions on what RPM peak HP will be, how much HP you think it will be, and maybe even a guess on torque if you want.
Old 10-17-2006, 07:19 PM
Bumpstick's Avatar
Hammer and a torch
Gotta be first...
peak @ 5200/338hp (best pull)
torque @3400/376 ft lbs...
Old 10-17-2006, 07:40 PM
Jmark's Avatar
Guess I'll be second? LOL
peak @ 8200/188hp (don't mind the scattered parts)
torque @2400/66 ft lbs
Old 10-18-2006, 05:55 AM
If I win this do I get a beer or do I have to guess where the vortecs will crack to do that?
308 hp @5400, 355lb/ft @ 3300.
Old 10-18-2006, 06:16 AM
RPMиииииииииии1000ииии1500ииии2000ииии2500ииии3000 ииии3500ииии4000ииии4500ииии5000ииии5500
Brake_Tqииииии230иииии290иииии340иииии356иииии367и ииии372иииии370иииии359иииии322иииии276
Brake_HPииииии43.7ииии82.9ииии130иииии169иииии210и ииии248иииии282иииии308иииии307иииии289
Exh_Presииииии0.0иииии0.0иииии.1ииииии.1ииииии.2ии ииии.3ииииии.5ииииии.6ииииии.7ииииии.7
Int_Vacuumииии.1ииииии.2ииииии.4ииииии.6ииииии.6ии ииии.6ииииии.6ииииии.6ииииии.7ииииии.7
Vol_Eff_%иииии69.0ииии73.4ииии77.4ииии81.2ииии85.2 ииии88.3ииии90.2ииии90.7ииии87.6ииии83.4
Actual_CFMииии76.3ииии122иииии171иииии224иииии283и ииии342иииии399иииии451иииии485иииии507
Fuel_Flowиииии27.9ииии44.5ииии62.6ииии82.0ииии103и ииии125иииии146иииии165иииии177иииии185
A/F_Mix_Qalиии68.1ииии86.6ииии100.0иии99.8ииии100.0и ии100.0иии100.0иии100.0иии100.0иии100.0
BSFCииииииииии.638ииии.537ииии.483ииии.484ииии.492 ииии.503ииии.517ииии.536ииии.577ииии.641
BSACииииииииии8.006иии6.733иии6.055иии6.072иии6.17 7иии6.314иии6.490иии6.727иии7.243иии8.047
Friction_HPиии6иииииии11ииииии18ииииии27ииииии37ии ииии49ииииии64ииииии82ииииии106иииии135
Mach_#ииииииии.097ииии.146ииии.194ииии.243ииии.292 ииии.340ииии.389ииии.437ииии.486ииии.534
Piston_Spdииии580иииии870иииии1160ииии1450ииии1740 ииии2030ииии2320ииии2610ииии2900ииии3190
Piston_Gsиииии65ииииии145иииии258иииии403иииии581и ииии790иииии1032ииии1306ииии1613ииии1952
Overlap_%VEиии-2.9ииии-1.9ииии-1.4ииии-1.1ииии-.9иииии-.8иииии-.7иииии-.6иииии-.5иииии-.5
Int_AvgVelииии62ииииии93ииииии124иииии155иииии186и ииии217иииии248иииии279иииии310иииии341
In_InertiaPrsи.0ииииии.0ииииии.4ииииии1.0иииии1.5и ииии1.8иииии2.0иииии2.0иииии1.9иииии1.6
In_ResTunPrsии0.0иииии0.0иииии0.0иииии.0ииииии.0ии ииии.0ииииии.0ииииии.0ииииии0.0иииии0.0
Ex_AvgVelиииии70ииииии105иииии140иииии174иииии209и ииии244иииии279иииии314иииии349иииии384
ExTun_Prsиииии1.6иииии1.5иииии1.5иииии1.4иииии1.2и ииии1.3иииии1.2иииии1.1иииии.9ииииии.9
Lifter_Pump_UpNoneииииNoneииииNoneииииNoneииииNone ииииNoneииииNoneииииNoneииииNoneииииNone
Spark_Advиииии20ииииии24ииииии26ииииии28ииииии29ии ииии30ииииии30ииииии31ииииии32ииииии33
Old 10-18-2006, 09:22 AM
324 Hp@5250
357 Tq@3500
Old 10-18-2006, 09:23 AM
firestone's Avatar
http://teamrfc.gospelcom.net
I would say 330 hp @ ~5000 RPM 370 ft lbs @ ~3600 RPM
Adam
Old 10-18-2006, 09:29 AM
poncho62's Avatar
Wiki Edits: 5
There are 1293 jellybeans in the jar..............................
Well, that is about as close as I am going to get....
My guess, and I stress..."Guess" is......
327hp@5300 rpm
345 lbs of torque @ 3300rpm
What do I win besides a jar of jellybeans?
Old 10-18-2006, 05:00 PM
NAIRB's Avatar
12 horsepower
Old 10-18-2006, 05:14 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by NAIRB
12 horsepower
Doc here...
Uuuuhhhh.. and would that be with the cutting blade and bagger attached ?
Gee. I missed something..could have sworn he said SBC not B&S..(Briggs and Stratten) But then , My eyesight is poor..
(sorry, Couldn't resist..)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-18-2006, 05:18 PM
Nairb is still with us. Welcome back. I'll be in Coldwater on the 9th of Nov.
Trees
Old 10-18-2006, 06:12 PM
curtis73's Avatar
Wiki Edits: 16
Thanks all for the guesses. I know there is a bit of a mismatch in peak flow and cam duration; that is to say the vortecs flow more than I need with this cam, but do you really think that hp will peak above 5000?
I was thinking more like 4800-4900, some have said as low as 4600. Desktop Dyno is telling me 5000.
Keep the guesses coming. I personally have to reject the obvious ones, but I do have to laugh at
Old 10-18-2006, 06:56 PM
NAIRB's Avatar
Trees
I am still with you, but Trees, I moved to Lincoln Nebraska.
I now work as a tech with Speedway Motors. I couldn't handle the prosperity of Cimarron any longer.
Old 10-18-2006, 07:00 PM
firestone's Avatar
Lincoln huh, that's where I live. How long have you lived here?
Adam
Old 10-18-2006, 07:09 PM
Wiki Edits: 31
Originally Posted by docvette
Doc here...
Doc
it only takes approx 9 hp to move a car down the road at 70 MPH. he's figuring on a high performance engine
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Another how much power? stroker_SS Engine 4 08-04-2006 10:57 AM
