Guide Plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2003, 10:20 PM
GearHead69's Avatar
'70 Chevelle '70 C10
Guide Plates
I have 2 sets of different style guide plates. I don't know what to run.. The raised style of flat?? I will be running a flat tappet cam with 555 lift, do I really need them? Here's s pic to compare
Old 07-25-2003, 10:40 PM
johnsongrass1's Avatar
Race it, Don't rice it!
What are we working on here?
Untill we know more details then it's hard to say with any kind of certainty
Although, just guessing here, it won't make much difference to ya.
Old 07-25-2003, 11:08 PM
GearHead69's Avatar
Going in my 70 Chevelle project I just got. The motor is a 350 LT1 out of a 92 Z28: 0.030 over, 12.5:1's, Comp solid Magnum 555 lift cam, 492 heads, angle plugs, 64cc, 2.02's, "race port", Harland sharp roller rockers, Hooker super comp headers, Victor Jr, 750 Holley Double pumper. Car gonna be used street/strip car it will only be drove to local cruise in's and just around town so I can idle around and turn some heada with my thumpin cam, 3" exhaust and Flowmasters!! I already have big plans on the project I'm just getting started on and the car neede basically everything and I don't really want to rush (only want to do it once and be done) Hopefully it will atleast be running in a couple years and complete in 3years?? Thanks
Old 07-26-2003, 06:08 AM
Bumpstick's Avatar
Hammer and a torch
The offset design was to give a little less pushrod deflection at higher rpm because of being closer to the end going into the rocker arm... It might be of some benifit at 7000 rpm+...? The reg. flat style has been used for years but as engines began to rev higher and higher small changes came about... For street strip setup I would use the flats but if it rev it pretty tight then the offset would be the choice...
Old 07-26-2003, 07:06 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Wow, That`s certainly not the everyday street engine. It will take $6.00 a gal. race fuel to run a 12.5:1 with 555 lift. what trans are you using? And what kind of gears? Keep us posted.
Three years is a long time, Don`t lose interest. Good Luck.
Troy,
Old 07-26-2003, 12:00 PM
GearHead69's Avatar
Yes it will cost a lot to run the thing.. It cost a lot to go fast period, I don't care. Here in IL we have Cam 2 fuel which is leaded and 110 octane it's like $4.00 gal and Turbo Blue I think it's 108 it's not leaded, my buddys who run 14:1+ say both are not very good gas and sware by Sunoco fuels. I have it all planed out, I'm going to live at home the rest of my life!! I think I will run the flat style guide plates becasue the raised might bind with the pushrods with my fairly hight lift cam. Hey check out my website I put some stuff about my Chevelle on there: My Website
Old 07-26-2003, 08:44 PM
troy-curt's Avatar
14:1+??????????????????????on the street???????????
Old 07-26-2003, 09:37 PM
GearHead69's Avatar
Yes Denny drives his around town all the time.. He re-ringed it for the first time in 3 years last week. It seems pretty reliable, he can cruise the streets and drive to the 1/8th mile track run 6.60's and drive home. He and another guy have the same motors in different cars and I helped them build em, they are 434 strokers. It's a Dart 400 SBC with some custom crank that was very expensive, I think Denny said he invested 9K in just the motor.
Myns gonna be right around 12.5:1.. Pistons are rated at 12:1 but once I use the thin gaskets and have them re-surfaced it might be 12:5. My car is not gonna be street-able I'll just idle around town and do all of my stupid stuff on country roads, I think myn will be either idling or balls to the walls.. Like my house, there isn't a house in a 2 mile radius around it, I love it. Street racing is not my thing at all. I think I will have one of the fastest cars around that's driving on the street (not like those 434's!!), to me it's not worth the ticket when I know I could waste them.
