Guidecoat? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2006, 09:27 PM
blacklabzeke's Avatar
Guidecoat?
What type of paint should I use for a guidecoat? Is sandable lacquer primer spray can OK?
Old 03-30-2006, 09:33 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
Guidecoat?
Yes that will work fine, as you dont use much anyway, and it dries fast.
Old 03-30-2006, 09:38 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Yup. The cheap stuff. Don't get enamel of ANY kind. It will take longer to dry and gum your paper bad.
Now, If you got a little extra $$$ and want the BEST guide coat. Get 3M's Dry Guide Coat. I won't even think of using ANYTHING else anymore. This stuff will show ANY imperfection no matter HOW small. GREAT product.
Wet you ask?
No problem,just apply it BEFORE you drag the water out. No, It won't wash off once it's on.
Old 03-30-2006, 10:53 PM
Remember when you painted with lacquer paint and sanded it with 600 then buffed with 3M "Heavy Duty compound"? Probably not unless you are at least 45 years old. Well, that is what it is like using spray cans or anything else for a guide coat after you try the 3M Dry guide coat Bee4me recommended. It is Soooooooooo much better than aerosol cans it isn't even on the same planet.
Yes it looks pretty expensive, but it lasts a LONG time. I use it for plastic filler only (not doing any paint work these days) nearly every day. A container will last a year or so.
Old 03-31-2006, 06:10 AM
302 Z28's Avatar
I concur with the 3M Guidecoat, I will also never use spray cans again.
Vince
Old 03-31-2006, 06:33 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
before the dry coat came out i used my pounce bag. i hate spray can stuff.
Old 03-31-2006, 08:06 AM
Bee4Me's Avatar
I made the mistake of leaving my dry guide outside a couple of weeks ago after blocking the carb scoop and it got rained on.
The applicator was just soaked and water was inside the container. I thought it was ruined. So I squeezed out the applicator and carefully drained out the water in the cup and just let it sit. The water apperantly had no effect on the powder and after everything dried out,works just great.
So, IF you do get it wet or in my case soaked. DON'T throw it out. Just let it dry out and it should be good as new.
Old 03-31-2006, 08:39 AM
Thanks for the quick replies.
Slick Sand - Blocking evill Body - Exterior 30 02-16-2006 02:36 PM
Scratches in the primer filler after blocking Scode68 Body - Exterior 38 11-20-2005 10:05 PM
3m Dry Guide Coat??? HARDEIGHT Body - Exterior 17 10-21-2005 12:40 PM
body prep advice please grouch Body - Exterior 14 08-31-2005 09:36 PM
sanding curves Mrwood Body - Exterior 8 05-08-2005 08:56 AM
