Gum on leather - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2009, 11:47 PM
Gum on leather
The black leather seats in my DD (BMW 740i) have gum on the seat. Anyone have a good solution?
David
Old 08-28-2009, 12:27 AM
JeffB's Avatar
Gum Removal
Good Ol WD-40 is a great gum remover,spray some on the gum let it penetrate a couple minutes then spray some on a Turk towel and rub it off works great for getting it off carpet too.I used to work for a Textile and uniform rental company and the rental mats would get messed up with gum and would be taken out of service,after showing this to the boss I got a little bonus since it saved the company plenty of $$$ in replacement mats,to this day they buy WD-40 by the barrel.
Old 08-28-2009, 01:33 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You need to know what kind of leather the seat is made from before you do anything. If it has coatings on it to protect the leather, things like Goo-Gone, peanut oil, WD-40 (which has fish oil in it), vegetable oil, etc. might work. If it has really good full grain leather in it with no coatings, you have to be exceptionally careful. I would call a BMW dealer first before I did anything which might damage the leather or leave an oily stain.
Old 08-28-2009, 06:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Rub an ice cube on the affected area and see if the gum will come off.
Old 08-28-2009, 07:03 AM
Wiki Edits: 22
I just looked at the label on my bottle of Goo-Gone. It says not to use it on silk, leather, suede, or rubber.
Old 08-28-2009, 07:19 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Dry ice is supposed to work, but I have never tried it. Seems like you would not have to worry about leaving any stain with it though.
Old 08-28-2009, 07:47 AM
302 Z28's Avatar
McGuire's makes an excellent leather cleaner that I have used to remove gum from leather before.
Vince
Old 08-28-2009, 01:10 PM
Wiki Edits: 22
I think I would not try something on leather that can burn skin. It might just burn cow skin too.
Old 08-28-2009, 09:55 PM
Thanks for the replies. I think I will ckecj with a BMW dealer to see if there would be any issues with solvent type solutions. I will try some ice..........I doubt I could screw that up........or maybe I could?
Thanks again and I will post the outcome
David
Old 08-28-2009, 10:54 PM
Finger nail polish remover will take it off in a heart beat. Test an area of the leather first to make sure it is safe to use then go for it.
I see by the 2 posts below me nail polish remover is not a good idea. That is why I said TEST FIRST. I remember using it when I was younger to remove gum but it was not on leather seats. Thanks for stopping someone from possibility damaging there seat.
Old 08-29-2009, 07:36 AM
Wiki Edits: 22
Finger nail polish remover contains either ethyl acetate or acetone as its main ingredient. I would not put either of those on good leather, it could remove the dye.
Be careful what you try, or you will end up with a lot bigger problem than gum on the seat.
Old 08-29-2009, 08:39 AM
302 Z28's Avatar
It will also take off the finish as finger nail polish remover is primarily Acetone.
Vince
Old 08-31-2009, 07:17 AM
Wiki Edits: 22
No problem. You did say test first, but leather is a tricky thing to clean and using anything as strong as fingernail polish remover before trying other cleaners and methods would not be the way to go.
leather seats rodrieguz Interior 6 03-28-2009 07:47 PM
Rattle can spray for leather seats? staleg Interior 7 02-07-2009 10:12 AM
Interior money question jasrking Interior 21 10-30-2007 07:04 AM
Re-coloring leather DanTwoLakes Interior 7 06-20-2007 07:25 AM
dash board upholstery CARGUY Interior 7 11-17-2003 11:01 AM
