GURU help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2003, 09:58 AM
GURU help please
I keep getting a loud grind/ clank as i go to start my engine. Ive shimmed and reshimmed my starter several times. I have backed the timing off several degrees and this still occurs. The "clanking" stops for a couple of start up cranks but returns to this problem. Is there any guru out there that has ran into this problem before??
Specifications: Pontiac 400, super turbine 300 tranny, Mild cam
Old 09-20-2003, 11:20 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Have you checked the flywheel to see if the welds on the ring gear are broken, the flywheel can be cracked near or at the bolts to the crank, teeth on the flywheel could be worn or chipped.
You may have to put it up in the air, with the inspection cover off and have someone else turn it over (coil wire off) and watch the starter engagement to the flywheel.
Maybe you can see what is going on.
Luv the smell of NITRO in the morning.
Old 09-20-2003, 07:45 PM
New Member
Same thing was happening to my 454 vette. 1st check the teeth on your starter if the look ok then you will have to replace the engine ring gear. I did both and everthing is ok now.
