gusher of oil from oil pressure sensor on sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 09:19 PM
i thought the oil pressure sensor had broken because of the oil that was leaking out of the base of it, so I ran to the auto parts store and bought a new one, however it won't stop leaking from there even with some silicone in the threading
the engine seems to have way too much oil pressure and I'm not sure whats going on
Old 08-18-2012, 10:02 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You put Silicone or thread sealer on the threads? What's the oil pressure?? Is this a new motor?
Semper Fi
Old 08-18-2012, 11:18 PM
I have always used teflon tape (4 wraps) on the threads. BTW you didn't answer the question of how much oil pressure do you have at idle.
Old 08-21-2012, 09:56 PM
well I've never seen this before
for some reason the rear of the intake didn't seal well, and through here it leaked oil profusely, about a quart every hour the engine ran
never seen something like that before
Old 08-22-2012, 01:16 PM
1971BB427's Avatar
Are you sure it's leaking from the sender, and not just the rear intake seal? Sounds more like it might be a blown or dislodged seal.
oil pressure sbc dave350v8 Engine 11 07-27-2011 10:46 PM
SBC oil pressure ??? 47 Coupe Engine 2 09-04-2009 11:26 PM
Oil pressure sensor/temp wire colors? jagurit Electrical 7 04-09-2009 08:31 PM
SBC: How much oil pressure is enough? 66Chevelle Engine 3 05-12-2008 10:39 AM
SB Ford oil pressure sensor Irelands child Engine 4 09-30-2006 05:37 PM
