Gutless 94' 350 needs a cam, but which one ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 12:03 AM
79monster's Avatar
I recently aquired a 94 suburban that is cherry but gutless, I wanna throw a cam in the 350 to wake it up a little to justify the already bad fuel mileage, Engine is stock everything w/ fuel inection, not lookin to race since im on airbags but want the xtra power when i need it. any cam suggestions ?? new springs mandatory ? new timing chain while im in the area ?
Old 09-08-2009, 12:07 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Your TBI doesn't need a cam, it needs a lot more. The TBIs were limited by head flow, cam timing, compression, TB flow, and a computer that won't take much modification. I don't want to shoot you down, but the TBI combo was well-matched to the 190 hp it made from the factory. You can't just stab in a cam and make more power, you have to ditch those wheezer heads, and most likely ditch the TBI.
Old 09-08-2009, 12:13 AM
79monster's Avatar
so what does the computer control ? can I use a different motor that is carbuerated and ditch the computer?
Old 09-08-2009, 12:15 AM
techinspector1's Avatar
Wiki Edits: 326
Not in California you can't.
Old 09-08-2009, 12:18 AM
79monster's Avatar
so it controls emmisions, injection and timing ? In theory though I can use carbuerated and not need ECU ?
Old 09-08-2009, 12:28 AM
Wiki Edits: 326
Old 09-08-2009, 12:30 AM
79monster's Avatar
so then i need the computer modified? can i swap for a newer one like a 98 ?
Old 09-08-2009, 12:41 AM
Wiki Edits: 326
I don't know, I just had to say it again
Old 09-08-2009, 06:28 PM
California requires that you qualify for emissions and does not permit changes from the fuel injection and emission equipment you have unless you put more modern and stringent equipment in the truck that is functional and engineering design compliant with the law.
The 94 engine is an OBD I, TBI system it can be hopped up and remain emissions compliant but not by much without a lot of money. You must use components that have a California Air Resources Board (CARB) certification or Exemption Order (EO) The EO doesn't mean what it seems to mean, it means the parts have been tested and meet the OEM emissions requirements and standards for the year of the vehicle. It doesn't mean you get an exemption from emissions testing. This engine also suffers from having Swirl Port heads, they top out around 4000 RPM, you may not use Vortec heads under California Law as they do not have an EO.
Edlebrock sells a cam for this engine it is 3702, it does a good job of waking this motor up and usually doesn't upset the emissions to a point of failing the test. But given the age of this truck, it may be nearing it's limit already, so you'll need to determine how much space you've got between what it tests now and what the legal maximums are. the cam will eat into that space. Not so bad on engines in good shape with a new cat converter, to really bad on tired engines and converters. Failing an emissions test in California is a big deal, they will refuse plates till it's fixed.
There are many other things you can do to pump this engine up to some really impressive numbers, but these things are not cheap to do as you still have to get past emissions which means the engine needs to be spot on. But better heads, better pistons, bigger TBI, headers, something that looks like duals but legally isn't, custom computer chip can be done and pass emissions but you've got to bring a lot of money and/or have a lot of talent. By the way, no a later model computer, it is completely different starting in 96 these are what's known as OBD II systems. They are not backward compatible unless you bring everything as in the engine, transmission and all their systems from the 96 and later vehicle, then you get to go to a technical referee before you get to the test which you still have to pass.
Remember if you have so much as the Check Engine light illuminated, you don't even get to first base. They won't even talk to you.
Bogie
350 Buick TBI Cam help!!! mnstreetrodder38 Engine 4 04-30-2009 02:26 PM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 05:12 PM
Cam upgrade for 350 Goodwrench david ahluwalia Engine 4 12-19-2008 01:38 PM
350 build upgrade cam azbandit Engine 14 06-17-2006 07:00 PM
350 L79 cam & vortecs? VEGA 3503508.5 Engine 11 05-22-2006 08:11 PM
