For the guys who like air! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2006, 12:44 PM
Simplicity's Avatar
The car turned out really well. We are very happy with the way everything went. We used RE72's all away around, Asco 3/8" valves, 3/8" smc line, AZ Pump, 7.5 Gallon Hoosier Tank, and fresh shocks all the way around [belltech nitro drop up front] monroes in the rear. Custom mounts all around. All DOT Brass PTC Fittings. This was not a "show" install, just a basic street install for the compressor system. Everything was tucked up under the rear decklid, still has a full trunk. And you can service the system very easily.
3/8" was definately fast enuff for this car!
and the car reaches ride right about 60 psi in the front and 35 psi in the rear and gets mad lift at 100 psi. Hopefully if the weather dries up I can get some better shots outside in the sun.
Old 02-04-2006, 07:23 AM
budthespud's Avatar
Diehard Chevy Guy
Nice work!!
Nice work Simplicity Like I said before I'm looking forward coming to Toronto and checking out how you can fix me up with a air system!!!
Old 02-06-2006, 08:18 AM
Simplicity's Avatar
Here is one of the gauges.
Link deleted by Moderator
We do not allow advertising links........
Deuce......
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
air compressor maintenance CaPrI_MaN Garage - Tools 8 10-04-2006 11:14 PM
shooting clear vinvango73 Body - Exterior 3 10-29-2005 12:24 AM
Help! Jeep Idle Air Control 68NovaSS Engine 1 09-16-2005 05:17 AM
WWWOOOHHOOO Air ride baby! flamedfordbronco Hotrodders' Lounge 8 03-11-2004 06:43 PM
