H.E.I Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2008, 10:47 AM
Last journal entry: 454
H.E.I Question
Will a H.E.I from a sbc fit and work in a 96-98 chevy vortec truck engine?I'm trying to set one up with a quadrajet.
Old 04-16-2008, 10:53 AM
yes it will but do you plan to use a roller cam?
Old 04-16-2008, 11:09 AM
If it will work fine with the edelbrock aluminum intake,Quadrajet,and the H.E.I then yes I would use the roller.If not I have a compcams 440/440 inch lift flat tappet cam.Would That work in the vortec block?
Old 04-16-2008, 11:27 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You should install a bronze distributor gear with a roller cam.
Old 04-16-2008, 01:47 PM
Yes, the only issue is drive gear compatibility with the factory roller cam. GM sells a Melonized steel gear, it's OEM on engines with factoy rollers, the P/N is 10456413, should cost from 30 to 40 dollars. This has much better wearing qualities than either bronze or composite gears and will not tear up the cam's gear.
Bogie
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
