Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - H.F. Portable sand blaster not blasting
Old 12-17-2011, 05:05 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I have one of those after you get the water traps on it and the valves replaced it'll work just fine but when mine gets plugged up all I do is put my finger (gloved) over the nozze; it'll unplug it quick....The only problem I have with mine is the sand valves wear out fast and need to be replace often...That abrasive wears a hole in the brass valve body especially the nozzel valve
