Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - H.F. Portable sand blaster not blasting
Old 12-19-2011, 07:49 AM
matts37chev's Avatar
matts37chev matts37chev is offline
& matts38chev
Last journal entry: Try again
Originally Posted by oldcpecdr
Not to hi-jack this thread but am looking at a similar unit for a small job...does using glass bead help eliminate the moisture issues ?
Thanks...
Mike B
if you are only doing small jobs
I have had pretty good luck with very inexpensive siphon type blaster
I actually just use real sand from work that I clean and sift into five gallon buckets
I would think with some store bought blasting media it would be even better
same rules apply dry air and sand
