Hello all,
I had purchased a harbor freight (HF) sand blaster with vacuum cleaner attachment. I thought it was the greatest invention in the world. Unfortunately it was not a very agressive blasting unit so i returned it and got my money back.
Details
I found a 20lbs portable sand blaster on Craigslist for $20 so I went and bought that as a replacement. I thought this pressure vessel type blaster would work better than a venturi type blaster. Pictured:
The guy I bought it from said it worked. I have had this thing sitting in the garage for months. I can't get it to blast. I removed the valve on the bottom of the tank and replaced it with a piece of straight pipe. This valve was used to let the sand flow from the tank into the "Y' fitting that then brings the sane to the gun. I decided that I would never need to reduce the amount of sand flowing from the tank.
I use to have a filter at the top of the tank between the tank and my air line going into the tank. I got rid of this because it broke.
Direct Question for the lazy reader
When I try and blast air is flowing from the nozzle. Very little IF ANY media flows out of the nozzle. I completely opened all the valves at the top and the bottom, but that didn't change a thing.
Why wont thins work? Any suggestions on what to fix?
I will post some pictures later to demonstrate the valve setup on the blaster.
You have to have pressure on the sand in the pot top (to push sand down), you have to have a valve ( at the bottom) to regulate the amount of sand coming out to nozzle. there should be a little less pressure pushing the sand down and an more on the nozzle to help suck the sand into the hose. Remember, more pressure the harder it cuts and , more sand, less cutting and heat it will create on the part. Your air supply has to be dry or it'll cause the sand to ball up. You really need a receiver tank to give the air time to let the moisture steal out. intake from air supply on top, discharge on top a drain **** on the bottom open just a little to help keep the moisture running out. It take a lot of air flow and pressure (80 psi or better) to sand blast.
Glass bead will not relieve moisture issues..you need dry air..regular sand will clog one of those units probably the clog is in the nozzle for the OP..
I call it SAND but I am actually using a product called "Black beauty". "Black Beauty" is one fo the most common abrasive blasting medias there is. Its efficent, reusable and fairly inexpensive.
I wonder if this was the problem. Would this be the issue? I had try glass bead once, that didn't work either.
I understand your point completely about the pressures at the different points of this blaster. But, the valves used to adjust these pressures are just a simple ball valve. These are not veyr precise valves where the pressure can be fined tuned.
Look at the picture I have attached. There are two valves at the top of the tank. One controls air pressure going into the tank. The other goes downward to where the sand gets pushed out from the tank to push the air/sand to the exiting nozzle. I thought both of these should be completely open to get the maximum blasting efficency. Although, I have tried adjusting one valve at a time to see if I can get sand blasting, your comment make sense to not have the same pressure at both locations.
I am really starting to wonder if I need a filter or some sort of additional reservoir in between the tank and the airline??? The filter I had previously run was this:
Maybe I should run something like this?
I wish there was a one way valve that would not let debris back into the airline...
The valve absolutely has to be there. Changes in pressure or volume of sand can require it to be tweaked making it dump sand one minute or not flow any the next. It is a required member for operation.
Dry air is an absolute must. I have used the small filters which help but nothing replaces a good drier. An air drier is a must if much blasting is done.The volume of air just works the air compressor heating it up and is the only way you can adequately overcome the moisture from the heated air compressor.
I also got rid of the deadman. After hours of using the blaster I found that a quick coupler screwed in the end is easier to use. I buy them by the handful. When they wear through I throw on another. The hole is slightly larger which means more volume, surface area and less air speed meaning slightly weaker. It has worked well for things I have used it for.
Just a note about blasting sheetmetal since this has come up a bunch of times,
It's a misconception that sandblasting heats a part and warps it, the warpage is caused by the peening effect not from heat. I mention this because many parts have been ruined from warpage because steps were taken to prevent heating when heat is not the problem, high pressure does however contribute to warpage but blasting at direct angles is the biggest culprit. About two years ago this subject came up and a couple of us decided to prove or disprove this heat myth so using an IR thermometer we monitored the temperature on an old truck hood while sandblasting the opposite side. Starting with a temperature of 68 to 70 degrees before blasting we expected to see little change as the blasting started but surprisingly it actually dropped about 4 to 6 degrees! I would guess the cooling effect would be from the air flow but whatever the reason the temperature on the backside of the metal being blasted actually cooled slightly even with the metal warping. The real reason fro the warpage is the sand acting as millions of tiny peening hammers that displace metal causing the surface to "grow" and thus to distort, this effect is cumulative and attempting to keep the part cool by whatever means will not prevent it from warping.
Here's a little more on the heat myth that's caused so many problems in the past. Lot of good info here and for anyone even considering sandblasting sheetmetal this is a good read that just might save someone a lot of headaches.
I have one of those after you get the water traps on it and the valves replaced it'll work just fine but when mine gets plugged up all I do is put my finger (gloved) over the nozze; it'll unplug it quick....The only problem I have with mine is the sand valves wear out fast and need to be replace often...That abrasive wears a hole in the brass valve body especially the nozzel valve
With quite a few of that type of sandblaster, "Black Beauty" does not seem to work too well. The white sand is finer and works way better. BUT, you need everything dry. Both the air and the sand.
if you are only doing small jobs
I have had pretty good luck with very inexpensive siphon type blaster :thumbup:
I actually just use real sand from work that I clean and sift into five gallon buckets
I would think with some store bought blasting media it would be even better
same rules apply dry air and sand
I appreciate all the good info. I need to buy some new filters to try and dry things up. I don't think my current problem is a clog though... But I don't know for sure.
I can dry the sand I am using pretty easily. At work we have a fairly large oven than I can put the sand into. I have done this before and it works fairly well.
DEADBODYMAN
What type of valves are you using? The same type that came on the blaster? Maybe the issue is the valves that are on the blasting unit?
Finger over the blasting tip works great! I use that trick in my siphon type blasting cabinet.
I was thinking about my situation a little more and just realized what you were trying to demonstrate with this picture and post.
You eliminated the valve with cone shaped nozzle attached to it. So you have lost the control to turn the blaster "on" or "off". But who cares about that right? Because you control the amount of air entering into the pressure vessel, you can turn it "off" from there.
Yes I have lost on off at the valve. I could put an on off at the pressure source. Off would not be instantaneous. It would take a few seconds for the air to bleed down. Frankly my quick connect is my on off. When you pull the quick connect it bleeds down pretty fast. When you connect, you have a second or so before the air builds up.
I know some will say what a big deal it is to have a dead man but basically the blaster is not that aggressive. Even dropping the end it just flops around a bit.
The real advantage is, when you hold it for a long period of time the less weight and mass is far easier to hold and direct. It is also easier to get into tight spaces.
A person could install a 12vdc solenoid valve on the supply air to the tank. run a door bell wire up to the end of the hose and put a press button switch at the end or you could use a foot pedal. Power the thing with a 12 volt motorcycle battery mounted on the tank. Simple cheap and easy.
I have a similar problem with Black Beauty (20/40) grit in my blaster. It's all in the setting of the valve at the bottom. Unfortunately I haven't figure it out either. Open the valve to much and the media clogs the spray nozzle. Not enough and it clogs in the valve at the bottom of the pot.
I need to get out there and play with this blaster again. I've been busy welding and assemblying the car. I really need to dedicate some time to getting the blaster working. I am kind of worried that because I eliminated the valve at the bottom of the tank, I might not be able to get it back on. I had to re-thread the hole at the bottom of the tank to install the pipe that replace the valve...
I have been using the black blasting Medea form Menards and started having a devel of a time getting the valve adjusted right. I was using play sand which was $2.50 per bag which worked pretty well. I might try mixing them a little next time to see if I can get the valve to work a little better.
This was the best advice from this thread. This nozzle works great. I didn't even drill it out to open it up.
I did change my blasting media to Aluminum oxide 80grit
I am still having issues with consistent blasting. When i fiddle with the valve the blaster will BLAST great for a few mins. Then, it acts like it is clogged and stops blasting. I fiddle with things more and it will blast again.
It's inconsistent and unpredictable. By the end of the day I was covered in dust and was frustrated.
I have more blasting to do, but I really need to get this figured out before I can get too involved with it all.
Anymore suggestions?
I downloaded the manual from the website. That was the second best advice
I have the same 40lb blaster and also used Black Beauty with the same issues. I could take the top fill cap off, stick a wooden broomstick handle down in the tank and it would come out wet with the media sticking too it. Bottom line is you must absolutely have dry air. The pressure pot is way more efficient but a siphon unit has the advantage of not contaminating the hopper with moisture from the compressor.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
