H-Pipe or not H-Pipe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2004, 11:45 AM
Once again the 86' crown vic. I'm ready to install the dual exhaust and the shop guy asked if I would like it with or without the H pipe. It's a $30.00 difference. Is there really any additional benefits added with the H-pipe or should I just save the $30.00 and go straight duals?
Old 07-22-2004, 01:02 PM
Siggy_Freud's Avatar
I would opt for the H-pipe (even more so for an X pipe). It helps equalize flow, pressure, and tone in the exhaust system. The X-pipes are more beneficial as its easier for air to change directions at 45 degrees than at 90 but any means of equalization is going to be beneficial. See if he can do an X pipe. If not I'd still go with the H.
Bringing history and technology together.
Old 07-22-2004, 03:03 PM
bullheimer's Avatar
NEVER use credit cards!
for $30 i say hell yeah
Old 07-23-2004, 06:23 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
thats very cheep
Old 07-23-2004, 06:40 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Go with the H, but and X would be better. For normal driving you wouldn't notice the difference between and H and X pipe. However, when under heavy throttle most exhaust gases will go past the H crossover and you loose most of the benefit, and X pipe on the other hand forces the exhaust to blend.
Mike
Old 07-27-2004, 06:02 PM
Carbed95GT's Avatar
Evil as I wanna Be
Last journal entry: First time out in 8 months!
$30 is dirt cheap. For the Mustangs, I never paid less than $150 for an h-pipe. Go for it.
Old 07-27-2004, 10:29 PM
There is a guy on ebaymotors selling x pipes for about 30 dollars +s&h. ubendman or something
Old 07-29-2004, 11:18 PM
mitmaks's Avatar
Last journal entry: Grille
that cheap for h pipe but id go with xpipe for more hp/tq
Old 07-30-2004, 01:17 AM
arch's Avatar
My bike has 4wheel disc brakes
hmm... in MD its illegal to install an exhaust without an H/X pipe. Shop and possibly owner can be fined $100,000, & Jail time for it.
at least for any car without special tags on it
Old 08-01-2004, 10:25 AM
Meangreen's Avatar
Is that true????
Old 08-01-2004, 11:25 AM
Ghetto Jet's Avatar
no, that's false.
Old 08-01-2004, 12:02 PM
arch's Avatar
False?? No...
Maybe I misunderstood the law...
However for emission-required cars H/X pipe MUST be installed. (If orignally equipped)
IE, you cant take an H/X pipe off a car that had it from the factory.
Old 08-01-2004, 04:14 PM
Ghetto Jet's Avatar
I know there is a $10,000 fine for any shop that doesn't put a catalytic converter on an exhaust system on a vehicle that originally came with a catalytic converter. However there is a loop hole, even if your car originally came with a catalytic converter if you remove it yourself prior to having an new exhaust system put on, the shop does not have to put a catalytic converter on the car when they put an exhaust system on.
arch I don't even know of any vehicles that come from the factory with an X or H pipe, but if they're are any I doubt it's illegal to not replace and x/h pipe as it has no effect on the pollutions emitted from the vehicle.
Old 08-01-2004, 04:32 PM
Ken. P.'s Avatar
go for the x pipe you wont regrete it. and if its too much then get the h its worth it also.
x pipe first choice h pipe second.
1970 SS 454-4spd elcamino 410 possi.1980 trans am CBB4spd 410 possi.
Old 08-01-2004, 05:16 PM
I'll see about the X-pipe first, Would it really make a difference to a stock 5.0 crown vic?
