Had a weird welder problem tonight - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 07:18 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I was welding up a bracket and all of a sudden the wire stopped feeding. I looked over and there were sparks inside the welder cover and I heard the wire bouncing around inside. I shut it down ad opened the cover and the wire had melted and broke off at the traction rollers, I didn't know if something had worn out and was getting a short. I pulled the broken wire and refed the spool and tried again with just a touch of the trigger. I could see the wire getting red hot, but all the way up to the spool. I thought that was weird, the pastic spool would have to be grounded for wire to conduct that far up. So I pulled the spool off and sure enough, there was a little tang of wire sticking through the plastic spool - weird huh?
Old 04-22-2011, 07:30 PM
302 Z28's Avatar
Never seen that one before, glad you found it.
Vince
Old 04-22-2011, 08:52 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
wow, that could have been ugly
Old 04-22-2011, 10:10 PM
put up or shut up
This sounds familiar...a kid we had was welding something on a frame and called for me. He described what you did and said it happened twice in a row after fixing the wire. I looked down and the frame was touching the cart. I pushed it off the frame and we had a good laugh.
Old 04-22-2011, 10:24 PM
The mobile view is crap
I seen the problem as soon as I looked at the photo. Your welder is red and not blue, LOL.
Let say you didn't shut the machine off, would it just have continued to do that until it hit the duty cycle then shut the machine down?
Old 04-23-2011, 07:53 AM
Arrowhead's Avatar
Wiki Edits: 5
No, as soon as I let off the trigger, the power is cut to the wire in the spool.
Very weird problem. Nsomnia Electrical 4 09-05-2008 02:50 AM
Weird TCC problem blacklabzeke Transmission - Rearend 16 05-15-2008 12:07 AM
Weird problem with my gun STATUTORY GRAPE Body - Exterior 3 04-07-2007 07:22 AM
Weird problem DoubleVision Engine 5 08-01-2004 08:34 PM
weird problem smallz Engine 5 01-25-2004 10:09 PM
