Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hair Pin (Radius Rods) Installation Question
Old 09-19-2010, 07:24 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Looking at your pictures, you need to swap the spindles from side to side. Having them reversed as you do will cause the "Ackerman" angle to be off and you will have the steering geometry way off. To best understand this do a search for "Ackerman Angle". Basically what this is can be shown if you draw a line from the center of the tie rod hole in the steering arm, thru the center of the kingpin on both sides towards the rear, the intersecting point should be about the center of the rear end. Handling will be very difficult at any speed the way you have it set up. If you want to keep the spindles as you have them, you must heat and bend the steering arms outward towards the wheel rim to correct the angle. This can seldom be properly corrected this way as the steering arms will tend to hit the rim before achieving the correct angle needed. Best to put the spindles on the correct sides and lower the steering arms to clear your frame.
