Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hair Pin (Radius Rods) Installation Question
  #17 (permalink)
Old 09-19-2010, 08:05 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by hotwheels1
If i swap the spindles back to the opposite sides, the steering rod hit's the frame.
You can modify the existing arms to clear. See the illustration below. Another alternative is to remove the existing steering arms and replace them with aftermarket dropped steering arms. They are available in 1 3/4" drop or 3 3/4" drop. The pictures below are from a Speedway Motors catalog for illustrative purpose. I believe Chassis Engineering manufactures a set of dropped steering arms that mount flatter and clear a dropped axle better than the ones I show below. Left click on the images for a larger view.
ID:	48173   Click image for larger version
Name:	dropped steering arms-a.jpg
ID:	48174   Click image for larger version
Name:	dropped steering arms.jpg
