Hair Pin (Radius Rods) Installation Question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-19-2010, 08:35 AM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Thanks frisco. I will have to sit and relook at the front end. If i swap the spindles back to the opposite sides, the steering rod hit's the frame. I have already cut the frame to spring shackle to bring the frame up off the ground a couple of inches. thanks for the heads up and i will do some reading on the ackerman angle.
doug
  #17 (permalink)
Old 09-19-2010, 09:05 AM
Frisco's Avatar
Glad To Be Here
You can modify the existing arms to clear. See the illustration below. Another alternative is to remove the existing steering arms and replace them with aftermarket dropped steering arms. They are available in 1 3/4" drop or 3 3/4" drop. The pictures below are from a Speedway Motors catalog for illustrative purpose. I believe Chassis Engineering manufactures a set of dropped steering arms that mount flatter and clear a dropped axle better than the ones I show below. Left click on the images for a larger view.
ID:	48173   Click image for larger version
Name:	dropped steering arms-a.jpg
ID:	48174   Click image for larger version
Name:	dropped steering arms.jpg
  #18 (permalink)
Old 09-19-2010, 09:11 AM
car enthusiast
That is awesome frisco, i will pull the front end apart and make the swap. Thanks a bunch for sharing those pictures, that makes it much easier for me to understand.
doug
  #19 (permalink)
Old 09-19-2010, 09:21 AM
Frisco's Avatar
Glad To Be Here
Here are some additional pics. Two show the stock steering arm with a dropped axle and almost '0' clearance. The next two show the same axle with the Chassis Engineering steering arms. Lots of clearance.
Name:	stock steering arm dropped axle-a.jpg
ID:	48176   Click image for larger version
Name:	stock steering arm-b.jpg
ID:	48177   Click image for larger version
Name:	chassis engineering arm-a.JPG
ID:	48178   Click image for larger version
Name:	chassis engineering arm-b.JPG
  #20 (permalink)
Old 09-19-2010, 09:27 AM
car enthusiast
That is awesome. Hopefully i will be in the garage today and i will swap everything over and see how much room i will actually have.
  #21 (permalink)
Old 09-20-2010, 04:03 PM
car enthusiast
Alright, it took me allot of work, but i think i got the front end back together and sitting better then before. (i haven't swapped my spindles yet.) As you can see, the frame used to sit about 1/2" off of the ground, now it's up about 3".
ID:	48212   Click image for larger version
Questions on floating or pressed fit pistons and rods for SBC 350 eric32 Engine 7 10-30-2015 08:21 AM
Jag irs radius rods a5llx Suspension - Brakes - Steering 4 04-16-2008 01:41 AM
"Basics of Basics" Rebuilding hinges. MARTINSR Body - Exterior 0 09-30-2007 12:16 PM
TPI 350 Distributor installation question? mySR7D1 Engine 6 04-06-2003 05:25 PM
Cranks, Rods and company question HemmiGremmie Engine 1 09-11-2002 08:44 PM
