Half Din Switch Panel....What Size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 10:09 AM
Tominator's Avatar
Trying to determine the proper size of the panel that would replace the filler panel/pocket that is on a standard 1.5 Din stereo adapter.
The single Din size is 2" and that follows that 1/2 Din is 1", but that does not allow for mounting the panel.
Does anyone have the proper measurement for this panel?
Trying to determine this measurement BEFORE I take the dash apart thanks!
Old 03-17-2007, 12:06 PM
Single DIN receivers have face dimensions of 50mm tall by 180mm wide. A double DIN is twice as tall and the same width. 1.5 DIN is 75mm tall.
Old 03-17-2007, 02:30 PM
Tominator's Avatar
Those are the standard dimensions, but I'm after the dimensions of a switch panel that could attach to the 1/2 DIN opening that remains after a standard DIN size radio adapter is installed.
The size of the panel in question would be larger than 1/2 DIN size to accommodate mounting of the panel.
It is that dimension I seek.
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
Switch panel for 32 ford dash ford427deuce Interior 2 12-24-2004 05:29 PM
Did a search and still have questions. Door Panel help please -pics inside- 87 c10 from scratch Interior 6 10-11-2004 07:01 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
