Half shaft splicing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 08:31 AM
Animal's Avatar
Dominators Hot Rod Club
Last journal entry: On the run
Half shaft splicing
To get power to the wheel from the Porsche transaxle to the Fiero hubs, I either have to splice two shafts together (slightly different diameters) or respline one end.
Any suggestions on which is better or stronger (427 hp)
Thanks
Animal
Old 01-31-2006, 04:41 PM
woodz428's Avatar
Troll Hunter
Resplining is most likely the stronger option.
Old 01-31-2006, 04:49 PM
Animal's Avatar
half shaft splicing
Thanks for your input. I will probably go that way.
Go Cart? mustangdude947 Engine 23 12-20-2005 10:02 AM
half shaft ujoint 81 vette 1-bassman Transmission - Rearend 2 09-29-2004 02:27 PM
12.5 hp go kart airbag_89 Introduce Yourself 2 08-24-2004 10:22 PM
Shaft rocker trouble uhhh not good Venturat Engine 1 08-04-2003 09:24 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
