Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Half Way there
Thread: Half Way there
Old 11-24-2003, 10:42 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
if the TV is not set at the proper minimum setting , the tranny will be in the fail safe mode if the fail safe check ball is in the valve body.
This raises the line pressure real high as if the tranny is at WOT, even at engine idle rpm.
