Half Way there - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2003, 08:45 AM
New Member
Half Way there
Earlier I posted about a 1987 Jimmy that would not move at all. Crosley told me it was the torque converter. Well I replaced the torque converter, and he was absolutely right. The truck runs fine in reverse and in first gear, but will not upshift at all. It stays in low gear all the time. Any suggestions, and Thanks for all the help so far.
Old 11-23-2003, 04:42 PM
poncho62's Avatar
Wiki Edits: 5
Did you hook the vacuum line back up to the modulater valve. That controls the shift.
If thats not the case, there is probably a problem within the trans.
Old 11-23-2003, 07:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool hmmm?
=========== there is no vacuum modulator on a 700/4L60 tranny.
Ted, have you looked at the govenor? Possibly it is stuck from something from t he converter.
It is under the round, press on cover near the rear of the main tranny case on the drivers side of tranny
Old 11-24-2003, 07:35 AM
New Member
I got real busy and did not get back to the transmission this weekend. I hope to start back on it today sometime. Does anyone think that the TV cable adjustmet has anything to do with this? We had a rough time fishing the cable back up and over the transmission. I am wondering if it got moved. Also, when you shift it from park to reverse or drive. It shifts pretty hard.
Thanks
Old 11-24-2003, 10:42 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if the TV is not set at the proper minimum setting , the tranny will be in the fail safe mode if the fail safe check ball is in the valve body.
This raises the line pressure real high as if the tranny is at WOT, even at engine idle rpm.
Old 11-24-2003, 06:23 PM
New Member
I don't want to sound too stupid, but what does this mean. Will the transmission shift out of first. It does appear like it has a lot of pressure by the way it jumps into gear. I keep thinking is something like the TV setting because it works fine now, except for shifting.
