Halfbreed speedometer cables - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2007, 10:51 AM
Hi guys, I have a question on speedometer cables. I need one for a 700r4 on one end and a 87 Mazda truck on the speedometer end. The same lenght as the orginal Mazda. I was thinking of cutting the Mazda cable in a straight place and silver-solder the end section of a 700r4 end to it. No cable places in Birmingham, or either not listed as such.
Has anyone ever tried to silver-solder one togather. If it was in a straight run of the cable it looks like it could work.
Old 08-24-2007, 05:51 PM
What does the Mazda end look like ??
The 700R4 uses the same speedometer end as the Turbo 350, Turbo 400, PowerGlide and other straight drive Chevrolets. So ... there is a good possibility that a factory cable exists.
On my 32 Fords with Chevrolet transmissions ... I have a Stewart Warner 160 MPH speedometer ... and it uses a different end than most GM vehicles ... but a factory GM speedometer cable for a 74 Monte Carlo with the cruise control unit mounted on the front inner fender ... fits perfect. It went from the transmission to the cruise control unit ... and another cable went from the unit to the Monte Carlo speedometer.
Old 08-25-2007, 02:24 PM
Try United Speedometer or abbott Enterprises. Both make custom speedo cable.
Old 08-25-2007, 08:16 PM
Thanks for the infor. Chevy does make a lot of cables. But mine is for the '87 Mazda ext-cab B2000 with a 700r4 and a vortec v6 in it. I will check the speedometer end tomorrow.
I checked United speedometer. I think I will call them Monday and see what happens.
Abbott Enterprises seem to do only big trucks and commerical stuff. Right now I think United is the best choice.
The mazda cable is round at the drive end, about 1/8" or so,in diameter,(metric), with a piece pressed out the side, like a small key. The diameter is larger than the drive gear hole in the 700. It's possible that I can reshape it shape with a die grinder and make it work. If not I can still make one out of two.
Thanks all for the help.
Old 08-27-2007, 08:35 PM
Deuce, I think you are right about the GM cable. I looked at about 10 today at O'reilys. None were the right lenght though. But all looked the same as mine on the speedometer end.
I ground down the Mazda cable and then filed it until it fit right in. If I kept the end centered with the cable, everything will be ok, I hope.
I got a Lokar trans dip stick, I hope to install tomorrow after I fill the pan.
Just wanted to let you know, you were right on about the cables. Thanks.
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 02:53 PM
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
Th400 electronic speedometer / speed sensor Chevy truck Twistedwrench Transmission - Rearend 2 08-05-2006 10:43 PM
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 01:13 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
