Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Halfway through rustproofing
Old 08-23-2012, 12:53 AM
tech69 tech69 is offline
put up or shut up
you can use a spray wand to get in there and use wax, por 15, or a rust encapsulator. Can also use a phosphoric acid to pretreat it but it may cause adhesion problems if you don't neutralize it fully or get it out. It looks like very minor surface rust. Nothing to worry about. Using por 15 as directed would do the job and then some.
