Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Halfway through rustproofing
Old 08-23-2012, 07:07 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
acid wont work very well now that theres oil on it.Matter of fact,you wont get ANYTHING to stick until all oil is gone. I would get all the oil off and sand blast the frame then with a big wire wheel cupand Ospho I get out the remaining rust out but dont try neautralizing it, its a myth, just let it dry .the steel will be protected until your ready to spray the primer which should be an epoxy for the best results and protection...
OR just do it like you are and oil it but dont try painting or priming it'll just peel off...
