Haliband quick change ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2002, 10:21 AM
New Member
Post Haliband quick change ?
Could somebody explane what exactly a quick change rear is and how it differs from a normal live rear end,thanks.
Old 06-30-2002, 02:20 PM
FASTFORD's Avatar
Post
on a quick change rear you can remove the rear cover and invert the 2 gears to change the ratio. for example, a paticular gear set in a qc,when the larger of the 2 gears is installed on the top shaft,the drive ratio could be 4.11,swapping the small gear to the top and the larger gear to the bottom would result in a ratio of 3.48. you can chek out qc`s by winters performance at www.wintersperformance.com
thats as simple as i can explain it,hope this helps.
