Halibrand Quick change 301 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2011, 06:06 AM
I have a Halibrand 301 quick change rearend that is live axle. I want to change it to positive traction or standard. Can this be done and if so how?
dneddinger@sbcglobal.net
Old 10-04-2011, 08:24 AM
live axles are all one part from one end to the other=can't be done on live axle.
Need to get other type of rear/closed axle QC can be done that way,but not open axle
Old 10-04-2011, 08:33 AM
Contact Speedway Engineering or Franklin.
I think the 301 is the center that used the Ford split housing bells. THere should be parts available but they could be expensive.
Old 10-04-2011, 09:36 AM
Halibrand
Thanks for the information and I was told it is a ford 3/4 ton Ford housing
Old 10-04-2011, 10:10 PM
Halibrand 301
I did get in touch with Richard at Halibrand he was extremely helpful. Got a bunch of good information from him.
Old 10-05-2011, 08:23 AM
can you share some of the information with the congregation? Perhaps split it into a new post?
Old 10-06-2011, 10:26 PM
Q/C rear end
They said several things can be done I just Have to decide which way I want to go.
Quick Change value? BigRoy1978 Transmission - Rearend 4 02-26-2011 07:37 PM
Quick Change radracer43 Hotrodding Basics 5 12-05-2005 04:48 PM
Halibrand Quick Change GSCHOOLEY Transmission - Rearend 3 11-01-2005 10:02 AM
Halibrand quick change Da' Bomb Transmission - Rearend 1 04-08-2005 12:30 AM
Halibrand Quick changes Melissa Introduce Yourself 3 07-10-2004 04:12 PM
