halo lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 08:42 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
halo lights
ok not really sure if anyone on here will know, or even if this is the right place to ask. i normally dont touch imports but my buddy bought new halo headlights for his 99 honda civic, everything hooked up to the stock wiring harness but on the new lights there are 2 red wires that come out of the bottom and i have no idea were they would hook up to. i am thinking they are for the blue halos and the lights didnt come with any instructions.
Old 08-11-2010, 06:11 AM
Wiki Edits: 31
power and ground.. wire them into a switch or parking lights
Old 08-11-2010, 08:54 PM
chevykid90's Avatar
well that was my first guess...but they are both red, so i basically just have a 50/50 chance of getting it right? so will both his halos be on even if he is in high or low beam? those lights are set up were it has one bulb for the high and one for the low and each have there own halo.
Old 08-11-2010, 09:27 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
these are leds ? think about it this way make a jumper, attach one end to the battery and just probe the wires one at a time, it is all 12v, so you will not hurt or blow it up. , maybe one red is for 1/2 and the other is for the other 1/2 of the halos around the bulb. I have never worked with the product but is can not be that difficult to figure out. How is it grounded?
Old 08-11-2010, 09:41 PM
chevykid90's Avatar
thats what i was thinking. i kind of did something like that, i pliced one into the low bean power wire and the other into the high beam wire. and that didnt do anything. they have to be what power the halos i just dont know how to go about hooking them up.
Old 08-11-2010, 09:56 PM
pepi's Avatar
The halos are leds so hook one wire to 12vdc and the other to ground if they do not light just reverse the wires. Leds a polarity defined or sensitive.
Old 08-11-2010, 09:59 PM
chevykid90's Avatar
ok i will try that. thanks for the help and i will let you know what i come up with.
Old 08-11-2010, 10:04 PM
pepi's Avatar
Good I will check back tomorrow from work... 05:30 comes early. I think you will figure it out.
Having issues with back lights on 96 chevy s10. eric32 Electrical 17 06-19-2009 07:18 PM
New wire harness. . . all my lights are acting funny elcaminodragster Electrical 12 02-24-2009 10:47 PM
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 02:06 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 07:51 PM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 04:20 PM
