Halogen conversion dim - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-15-2011, 07:45 AM
coupe66's Avatar
Looks like the Halogen 9007 bulb...
http://www.thefind.com/cars/info-hal...headlight-bulb
/Pete
  #17 (permalink)
Old 07-15-2011, 08:12 AM
That bulb looks like it is to into the reflector to far, is the bulb up by the lens. Most lights the bulb is back down in the cone of the reflector light is defused forward and out.
That looks like the base of the bulb, black plug is being reflected. It can be seen in the shot you have with the lens removed on the pass side head lamp.
Notice you can see 3 different reflections, from the back forward. First black plug is seen then the turn signal, the next reflection is the light, so about two thirds of what is being reflected is not head light. It can ever be seen in and on the drivers side. Maybe look over the instruction and verify the install, that bulb sure looks odd in its placement.
  #18 (permalink)
Old 07-15-2011, 08:13 AM
Last journal entry: Con't
Yep, looks like that. And comparing to a H4 picture they dont look interchangable unless socket is changed. Thanks again
And yes it was in wrong (see post 12)
  #19 (permalink)
Old 07-27-2011, 08:06 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
Originally Posted by pepi
It maybe to late for this information but I will pass it along anyway. The following is a great simple conversion that will give you knock out headlights, the only down side for you as I see it, is no turn signals you will need to mount them separate. The bulbs a 7 in round, real glass cut lens, the brand speaks for itself.
http://www.jcwhitney.com/vision-plus.../p2003796.jcwx
Are these dual beam hi/lo headlights? Couldn't find anything on the JCWhitney site.
Thanks,
Russ
  #20 (permalink)
Old 07-27-2011, 11:20 PM
Headlight conversion
I found a nice headlight conversion set up w/relays at LMC Truck online (reasonably priced)
  #21 (permalink)
Old 07-28-2011, 07:35 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Thanks,
Russ
Yes they are hi & low, they drop right in and use the same spade plug socket. You will be very pleased with the results, they are not fad lights, are very functional.
  #22 (permalink)
Old 07-29-2011, 08:25 PM
bentwings's Avatar
bentwings
I also added a relay for the low and another for the high beam. I gained a full volt at the headlights. They went from yellow to white. They still don't focus properly but setting the high so oncomming cars don't flash you works pretty well.
do halogen lights need relays? yragat Electrical 22 10-27-2010 10:37 PM
Bright halogen lamps 302 Z28 Electrical 14 06-20-2007 11:13 PM
halogen lights in a 37 chevy p/u junkyardjeff Electrical 3 10-23-2006 10:51 PM
halogen headlights ? bassmaster_93202 Electrical 15 08-11-2006 02:42 AM
Coverting 39 Olds Headlights to Halogen JohnTN Electrical 1 12-04-2004 11:36 PM
