halogen lights in a 37 chevy p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 10:49 PM
junkyardjeff's Avatar
When I was putting my 37 togather I was originally planning on using sealed beams but I found out 12 volt bulbs were available to use in the original headlight system,I like the look of the original lenses but even with 12 volts those bulbs are not that great. Is there any way I can use the halogen bulbs from a modern vehicle and put them in the original reflectors or are there any kits to do that. Jeff
Old 10-21-2006, 11:08 PM
Rick 5150 69's Avatar
have you tried here... http://www.rbsauto.com/
Old 10-21-2006, 11:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If your referring to the "Plug in " lamp modules on a late model vehicle , My only concerns would be high heat in a metal headlamp bucket..and possible shattering of the stock glass from high heat / Vibration...and water incursion under high heat through the bucket / lens..
Doc
Old 10-23-2006, 09:51 PM
Scotts67's Avatar
New Member
Just throwing in my 2 cents, I purchased the cool looking, high powered halogen bulbs on EBay for my 67 Camaro and was able to run them for about 15 minutes before it burned up my wires and the rubber boot it came with... good thing it was in my garage and I was paying attention or aside from the smoke there coulda been flames under the hood! There is such excessive heat put off by some of the aftermarket lighting that the stock wiring setup cannot handle it. This was with a plug and play setup for Chevy, good and bright for 15 minutes or so. That was my experience anyways...
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
72 chevy p/u over haul knight9481 Hotrodders' Lounge 4 03-30-2006 09:33 PM
whats the difference in gmc and chevy lights? tiresmoke55 Body - Exterior 0 01-20-2006 10:25 PM
Ford dropped axle on a 37 chevy p/u junkyardjeff Suspension - Brakes - Steering 1 12-17-2005 07:27 PM
ideas for reverse lights - '65 chevy truck Woogeroo Electrical 2 12-08-2005 05:48 PM
