Hammer and dolly set????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2009, 11:39 PM
Hie
I am a positiv enthusiast that want´s to make my own body work, I am very stuborn and want´s to learn how to straighten the sheet metal on my F100 truck on my own. At the moment I am looking for a Hammer and dolly set. Here in Sweden the selection of available hammer and dolly set is poor, I have been looking on two different set at two different warehouse and, though I dont know more than I have been reading on the internet and different magasines. I found the hammers in these set to be grinded in all possible and almost impossible ways (I think it is poor quality). The cost for these two set was $36 vs $53. Does anyone have a tip on where I can find a good set of hammer and dollies, I dont want this cheap stuff, it will probably ruin my soon to come experience in the garage. I am not affraid of ordering stuff from abroad.
Many thanks Jimmy
Old 09-23-2009, 12:02 AM
eastwood set
Old 09-23-2009, 07:13 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
IMHO, Martin Body work Tools are the best-
http://www.autobodytoolmart.com/mart...ies-c-980.aspx
http://www.martinsprocket.com/homeX.htm
Old 09-23-2009, 10:00 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As you progress you will find yourself making some of your own tools for sheet metal..i woudl suggest going over to metalmeet.com and learning from the pros about sheet metal..
Sam
Old 09-23-2009, 07:32 PM
jr.rodder's Avatar
I agree with 35window, Martin makes good body hammers.
Old 09-23-2009, 11:28 PM
Thanks guys
Now I have some real stuff to get starting with.
Thanks again
Jimmy
Old 09-24-2009, 09:21 AM
I agree Martin is the best! Also use pieces of old Railroad rail to make your own. Super high quality steel and heavy.
Old 09-26-2009, 11:38 AM
Wiki Edits: 27
home made tools
A Volkswagon Bug jack can be used for a porta power. water pipe will slip over the end for longer length. . a screw on flange with a shaped piece of wood to match the contour. a lot of usa cars from 60's thru 80's used 1/4 inch spring steel torsion springs for deck lids , they are 3 to 4 ft long . you can cut them in half then round off, contour , or point the end and and bend one end to a J shape with the L on the other end You use them to get into places you can't reach with a hammer. either pry or twist to raise dented areas. a flat carpenters wonder bar nail puller also works to spoon hard to reach areas.
Old 09-26-2009, 12:34 PM
Wiki Edits: 3
that is the hotrod spirit to make your own and innovate your own stuff..
Sam
Hammer and dolly ... I hate bodywork Deuce Body - Exterior 15 03-03-2007 07:49 AM
Hammer and Dolly Technique. coda618 Body - Exterior 6 08-11-2006 12:57 PM
Recomend a hammer and dolly '32ROD Garage - Tools 1 05-31-2006 09:21 PM
Hammer and Dolly tool review MARTINSR Body - Exterior 12 10-20-2005 05:33 AM
Hammer and dolly Maverick Body - Exterior 16 12-13-2002 09:39 AM
