Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hand cleaner, What do recommend?
  #18 (permalink)
Old 06-16-2008, 10:16 AM
oldred oldred is offline
Kevin, I have had just the opposite result with the smooth formula Fast Orange, were you using the pumice type? I suppose any solvent type hand cleaner would cause drying if used often enough, even Fast Orange, and I would think a tool and die maker would use quite a bit of it.
Also the Orange version of the GoJo, smooth or pumice, will cause drying of the skin because it is basically just regular GoJo and not the same as Fast Orange.
