hand cycling to aid break-in - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 05:42 PM
flat tappet cams need extra care to be broken in, I get it.
the cam and lifters were installed with gobs of assembly lube, and the motor (383 chev) is complete now except carb and ignition.
this might be the dumbest question youve ever heard, sorry. But it seems that you would be a couple steps ahead if you took a breaker bar to the balancer and cycled the motor over for a few minutes each day...hypothetically.
I just dont want my cam to go flat!
Old 01-16-2008, 06:22 PM
might not be a bad idea if you could spin it 2000 rpm with the breaker bar, and breath real heavy to heat it up. just kidding. wait and break in normally. sam-missle
Old 01-16-2008, 08:02 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
if you do what you're proposing it will probably wipe some of the lube off the cam
Old 01-16-2008, 08:07 PM
31 five window
Last journal entry: grill and rear end
I agree with both replys.When you are ready to start engine and break in make sure and prime the oil pressure,then start it and break in according to cam company instructions and you will be fine.
Break in oil flat tappet cam 71 c-10 Engine 4 11-17-2007 10:55 AM
Break lites don't work? 31 Ford A Electrical 13 08-23-2006 06:34 PM
Oil Weight Break In Again spanky36 Engine 2 06-18-2006 10:41 PM
Spring break is finally here, but....... onebadmerc Hotrodders' Lounge 3 03-18-2005 09:26 AM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
